Dreambox 800hd on cable
  • Juan Ker
    • 10
    anyone actually have one of these that doesnt picture freeze after a day or 2 due to not auto rolling.
    using the latest gemini
  • Curious123
    • 2591
    What cam are you using? Evocam 2.13 seems to work well on cable.
    • hotbaws11
      • 59
      Yeah I would have thought the only thing wrong here is the possible cam setup. Get that fixed and everything should be ok. I assume its just for the non FTA channels?
      On a sidenote, what is the quality like on the DM800 for cable for both sd and hd (well BBC) channels? using the dvi to HDMI cable?
      • 2tone
        • 483
        never had any probs with mine should have made a back up but forgot and put a sat image back on it so it will be a while before i do it again , there is a new gemini image out at the min might fix some probs also how many cams have you tryed out gemini has a load of them in its server if not already i would try some till you get one that works as for picture i had mine going through sd for most of the times i had it running on cable i thought it was ok picture was better but even better through dvi
        • Juan Ker
          • 10
          evo 2.17c which I download through gemini
          how do I find and install 2.13 (shouldnt 2.17 be better)
          • 2tone
            • 483
            is 2.13 not on there server as well if not im sure i seen a download for it on this site just ftp it over
            • westkill
              • 2378
              unzip
              open folder
              then you will see a tar.bz2 file
              ftp this to temp folder on dreambox
              go to addons>manual install (if still the same location on dm800 )
              then it should be in your cam list
              • Juan Ker
                • 10
                Originally posted by westkill
                unzip
                open folder
                cheers big ears
                • Juan Ker
                  • 10
                  I search the web and eventually found a key that worked and entered into the keylist, this was with evo 2.17, tried with 2.13 and got just a black screen
                  i know within a day or two the pic will freeze and im back to square 1
                  • Curious123
                    • 2591
                    What you probably need to do is copy the 'special' AU files (I don't have a link) to var/keys and var/scce directory on your dm800 and than switch to S*y Sports 1 and restart Evocamd 2.13.
