DREAMBOX 800c
  • Prendy
    • 44
    #16
    Thanks dctyper. Ive tried what you said but still nothing. So i started from scratch and reinstalled Nabliosat v12 for clone, cleared out the folders var/keys and var/scce and put the special keys/roms in usr.keys and usr/scce. Downloaded the latest Mgcamd 1.31 (also tried Evocamd 2.17) and restarted the cam. Switched to s*y sp***s 1 for 15 min but nothing.
    I did some more reading an found this from Devilfish.
    If you're using mgcamd, make sure the mg_cfg file is set to auto update. If you're using evocamd, its the camd_cfg file.
    If i need to do this i don't know how.
    Nearly there but still need help.
    • southpaw
      • 2233
      #17
      Hi Mate , send me a pm with an email address in , and i will forward you files and instructions
      • smirnoff_rules
        • 8603
        #18
        no need for pmS AND EMAILS ... this is a forum
        • southpaw
          • 2233
          #19
          yes i know this is a forum , however i cant upload to this forum a working config file ,
          only trying to help the guy out , as a decent member from this forum did the same for me , and i was gonna forward the email i got from him , which sorted this problem out
          • southpaw
            • 2233
            #20
            How do you suggest i go about helping him , or shall i just tell him to use the search function
            • smirnoff_rules
              • 8603
              #21
              u can upload to an external site like rapidhare and we can still see the thread to the finish then and it might help others ,, alot of threads stop when membesr pm one another and no one learns anything and the same thread start again that all l meant by it m8
              • southpaw
                • 2233
                #22
                www.4shared.com/file/198841953/a5fe3ca7/mg_cfg.html
                www.4shared.com/file/198841965/67b0ca51/nagrarom7.html
                www.4shared.com/file/198841986/603ab665/nagraram7.html
                www.4shared.com/file/198841990/90422211/nagraepr7.html
                www.4shared.com/file/198841992/7e4c433d/SoftCam.html
                I know for a FACT that these files work just dandy with Gemini & Blackhole.
                Firstly download and install MGCamD 1.31. Once it is installed copy the rom7 files to the usr/scce folder and copy the Softcam.key & mg_cfg to usr/keys. Once they are in place you need to chmod all the files to 755. I do this using flash fxp, everyone has their favourite method. To chmod , just right click the file in ftp programme , (when its on your box , not pc) select attributes and change number to 755 , this will apply the correct read / write settings etc ,
                You also need to have CS server running with mgcamd , again download thru blue button ,
                Good luck mate ,
                • southpaw
                  • 2233
                  #23
                  Credit for this goes to Scotster , as it was his email that contained all this info , i`ve only uploaded as told to by Smirnoff ,
                  Let us know if this fixes your problem mate !
                  • Prendy
                    • 44
                    #24
                    Will give it a go today.
                    • Prendy
                      • 44
                      #25
                      Nothing
                      Hello,
                      Did Everything you said but still nothing. I can get the FTA channels but s*y sp***S 1 is blank. Just get the info. Don't know what i'm doing wrong so i uploaded some photos.
                      Any ideas before i drop it in the fish tank!
                      Thanks.
                      • despdan
                        • 544
                        #26
                        Rename mg_cfg.txt to mg_cfg & restart box, also check that it's setup correct:
                        Another thing to try manual put keys in softcam.key file to make sure mgcamd is working. If it works then you know the mg_cfg file needs editing or your autoroll.key file. just looking at your photos your missing a autoroll.key file
                        • Prendy
                          • 44
                          #27
                          At Last
                          Your a absolute star Despdan. I changed the text like you said, uploaded an autoroll.key and autoupdate file, restarted the box, put s*y s 1 on and just like batman it went THWACK!.
                          Just also like to say thanks to Southpaw, Scotster for the files and my Dad for the many hours he put in while i got drunk.
                          Brilliant.
                          • Prendy
                            • 44
                            #28
                            Bouquets
                            Just need to sort out the channels now!
