Flashwizard and dm500c
  • Specialkey
    • 38
    Hello everyone,
    just a basic question,can I flash a dream 500c with flashwizard with ethernet cable on the network as you usually do with the 500s?
    Thanks.
    Joe.
  • smoggie
    • 863
    yes, just the same
    • westkill
      • 2378
      most images will not work as they are classed as maxvar images and are a bit different as they are bigger so flash wizerd pro will probally crash the box
      so use dreamup
      • Specialkey
        • 38
        what do you mean,crash the box while flashing or I will have an unstable box?
        I flashed couple of dm500s with flashwizard never had a problem.
        Thanks.
        • aftermath
          • 4345
          it depends.
          if your tying to flash a .fw2 backup over a different image thats not made by the same team, Most likely will brick the box, .
          best way is to flash a raw image before the backup fw2 image using dream up, but you can flash it with flashwizard pro , but needs to be under 8mb in size.
