how to install keys for 7025
  • westkill
    • 2378
    #31
    what ever image you have in the flash i think lt goto addon download barryallen from there i think its version 4.5.9 of the top of my head
    then you should see the other images on your cf card
    • micron123
      • 24
      #32
      7025
      On my 7025 I found that evocam 2.17 will work but will not autoupdate the keys.
      Now if I use evocam 2.14 then it will auto update the keys but will not unscramble the picture. What I do is run 2.14 to AU the keys then swap to 2.17 to clear the picture. I think there's a problem with the format of keylist.txt.
      Another way is to use mgcam which works fine The only problem is that mgcam will freeze the picture now and again.
      Hope that helps.
      By the way the folders to use are usr/keys and usr/scce
      • thered
        • Aug 2008
        • 4915
        #33
        looked at permissions for cam in bin file all set to 755 so that is correct yes?
        looked in my keys folder and scce although the folder is set to 755 everythimg in it is set to 644 would that be correct
        in reply to the last message i have evocam 2.12 because in all the forums i have read it seems to be the best by most users
        everything seems as it should but it still wont work any ideas anyone please
        <--thered added 82 Minutes and 3 Seconds later...-->
        just out of interest how would i try to put the codes in manually without autoroll just to see if that clears it
        • westkill
          • 2378
          #34
          quote :just out of interest how would i try to put the codes in manually without autoroll just to see if that clears it
          try this for evocamd
          4th post
          • thered
            • Aug 2008
            • 4915
            #35
            THANKS FOR THAT WESTKILL IM GOING TO TEST DOWNSTAIRS NOW
            BUT THIS MIGHT BE WHERE THE PROBLEM LIES I OPENED UP EDIT KEYLIST THERE WAS NOTHING IN IT JUST BLANK WITH A NUMBER 1 AND 2 AT THE SIDE
            I PUT THE NEW ROLL NUMBERS NEXT TO THE NO1 AND NO2 BUT HERES MY NEXT PROBLEM SHOULD THERE BE A SPACE BETWEEN THEM OR DO THEY RUN NEXT TO EACH OTHER DO I NEED THE 54 01 CODE IN FIRST OR DO I LEAVE THAT OUT ANSWERS ON A POSTCARD.........
            <--thered added 31 Minutes and 20 Seconds later...-->
            just tested sky sports ten mins no joy
            have i put keys in right do i need spaces or the 5401 code for my area b4 the code i put the numbers all in a row no gaps or slashes
            so no further forward
            • thered
              • Aug 2008
              • 4915
              #36
              still nothing try again tommorow if anyone knows anything feel free to join in
              lt fifth campaign evocam 2.12 keys and roms in files no picture where is it going wrong?
              • westkill
                • 2378
                #37
                it should look something like this
                in the key list text i think
                this is an example:
                N 5401 00 ************** ;
                N 5401 01 ************** ;
                ive experianced a few problems with evocamd 2.12 and 2.13 on the dm7025 latley
                but they work fine on my dm600
                so try this evocamd for the lt 5th image with a manual install ,delete other one first
                • thered
                  • Aug 2008
                  • 4915
                  #38
                  which folder will it be in to delete and do i need to delete the keys too
                  • thered
                    • Aug 2008
                    • 4915
                    #39
                    by the way found some new keys in my email 2day some nice chap must have put them there these are different to the ones i have got there is a lot more in the keys folder than i have in mine and less in the scce so would you recommend trying that before trying rhe evocam fix thanks
                    • aftermath
                      • 4345
                      #40
                      make a backup of your original ones first, i am thinking if there is a lot more then they might be for sat and not cable. ?
                      • thered
                        • Aug 2008
                        • 4915
                        #41
                        yeh good thinking il do that cheers
                        • westkill
                          • 2378
                          #42
                          ftp to the usr/keys look for the file keylist text ,right click on there chose edit,then clear all the info out and save it back to the box(dont delete the whole file )
                          put the the new evocamd in from the last thread
                          restat the dreambox ,then restart evocamd
                          see if that works
                          when the cam restarts it should generate the new keys in the" key list text"
                          if you want to check it and see if it has done its job later
                          then leave keys and scce folders as they are
                          try a encrypted channel then switch to another, then in the info bar should see the N change colour to green i think
                          hopefully you should get a picture
                          • thered
                            • Aug 2008
                            • 4915
                            #43
                            do i delete the old evocam if so where do i delete it from
                            • westkill
                              • 2378
                              #44
                              goto menu>lt menu>addons manager there should be the option to to remove or delete addons
                              i havnt got lt image on at the moment so i think thats is where it is
                              • thered
                                • Aug 2008
                                • 4915
                                #45
                                right i have done all that and guess what..............
                                its still the same i think ive officially cracked up any more thoughts ive got a feeling its something so stupid but no idea what
