gemini project 3.7 evocam 2.17 not a lot happening not even fta
tried mgcam with a lot more success clearing around 1 in 4 channels but i have no bbc itv ch 4 ect no sky sports or setanta but it is clearing quite a few channels strange how my fta have all gone blank apart from bbc1 scotland
hi m8
so it is starting to give some encrypted channels
i think the problem might be a signal strength issue
you need to check a few channels some that work and some that are not
and post the results
snr should be as near to or above 90%
agc shoulb be i guess 38 to 40 %
ber should be say any thing near to 0% as possible
is your cable on a splitter i think your signal might not be strong enough or can u try it without a splitter
if this is the problem have u got a tv signal booster knocking about you could try
most signal strengh is in the regions you are talking about i dont really see it being a cable problem i have no splitter and can receive every cable channel on my eurovox no problems
in earlier posts i have been struggling with encryption with all fta working fine now i have no fta apart from bbc scotland
the mind boggles
just had a look at a few channels itv is snr 94 agc64 ber 0 channel 4 is snr 93 agc 67 ber 0 sky sports ant of them all around 93 snr agc 76 ber 0 so the agc is high in these ones i cant view it seems
but why could i watch them b4 and why do they work in my eurovox
Reason: checked
the mind boggles
Hi sorry i haven,t followed your thred from begining i think your signal is ok 7025 tuners are quite good what image are you on now and what cam
i guess the eurovox has got different kind of tuner
hmmm ...have you got an f-connector on the end of your cable the end bit screws on, if so try loosen that a touch or tighten but not to much
im on gemini with mgcamd 1.3 at the minute ive tried evocam 2.17 doesnt clear much at all mgcam clears maybe 1 in 4
Some evocam are not decoding properly i had this problem some times if you look in the infobar it,s saying it,s decoding you got green N highlighted and other times you get sound no pictures try a evocam 2.17b&c
