DM 500 Help!!
  • badger187
    • Mar 2010
    • 17
    #16
    Yes it does, i get the following: Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\badger>ping 192.168.0.101
    Pinging 192.168.0.101 with 32 bytes of data:
    Reply from 192.168.0.101: bytes=32 time=7ms TTL=255
    Reply from 192.168.0.101: bytes=32 time=2ms TTL=255
    Ping statistics for 192.168.0.101:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 7ms, Average = 3ms
    • ManofScience
      • 650
      #17
      excellent. it's connected and can see it.
      what FTP Program do you have? or are you using dreamup?
      • badger187
        • Mar 2010
        • 17
        #18
        Now i'm really confussed!!!... i've just unconnected the dreambox from the router and pinged the same addy and i still get the same reply as above :S, it even still finds the same 2 ips in DCC :S??????
        • ManofScience
          • 650
          #19
          hhmm... oh well!
          plug it back in, go into the enigma settings, untick DHCP, give it an IP of 192.168.0.120 and the gateway would be 192.168.0.1.
          Try that, save the settings and reboot the box (thru the menus)
          (i'm here for a little while so do it now, i'll hang on!!)
          • badger187
            • Mar 2010
            • 17
            #20
            just tried what you suggested, still not connecting through DCC
            • ManofScience
              • 650
              #21
              have you tried pinging it? just to see if it's connected. 1 step at a time.
              • badger187
                • Mar 2010
                • 17
                #22
                it take it i ping 192.168.0.120? ive just pinged it and it said: Microsoft Windows XP [Version 5.1.2600]
                C:\Documents and Settings\badger>ping 192.168.0.120
                Pinging 192.168.0.120 with 32 bytes of data:
                Request timed out.
                Request timed out.
                Request timed out.
                Request timed out.
                Ping statistics for 192.168.0.120:
                Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
                • badger187
                  • Mar 2010
                  • 17
                  #23
                  B.t.w. i have smart FTP and flashFXP
                  • ManofScience
                    • 650
                    #24
                    so, setting a static IP doesn't work and setting an IP with DHCP - doesn't work. and thats with the normal patch lead to the router?
                    i'm running out of options. i much prefer Neutrino based images, i use DW 2.1 - the network config is much more straight forward to use/understand
                    • badger187
                      • Mar 2010
                      • 17
                      #25
                      do you have that image with keys etc? i'm willing to give it a try. i have a null cable modem so it shouldn't b a prob thanks
                      • ManofScience
                        • 650
                        #26
                        check PM's
                        • badger187
                          • Mar 2010
                          • 17
                          #27
                          Does anyone out there have a DM500 image with keys etc they could send me?
                          • ManofScience
                            • 650
                            #28
                            reflash that image but this time UNTICK flash erase. i sent u another PM
                            • badger187
                              • Mar 2010
                              • 17
                              #29
                              tried that image twice m8 still no luck becoming a nightmare... i'll stick @ it tho until it annoys me to much :P
                              • ManofScience
                                • 650
                                #30
                                did it flash though? does it boot?
