can I install a movie player for the DK 1.1 image so I can watch my AVI files from my PC
movieplayer for DK 1.1 Image
if only ... this would be the icing on the cake if they could play avi'sany information provided is for educational/experimental purposes only. -
any information provided is for educational/experimental purposes only.Comment
Hi Smirnoff,
Yes it lets me play AVI's direct from my mac.
In fact it lets me play anything VLC plays. (avi, wmv, mov etc)
You can even set up what are called server sets. This allows you to play movie files from up to 4 different locations on your PC.
You have to have VLC running on your PC for it to work and there is some initial set up.
I used this guide to set it up on my Mac.
How to DBox - VideoLAN Wiki
(Hope it was OK to post this!!)
I use it all the time. I can just play my DVDrips etc straight through my dreambox.Comment
its converting as u watch u mean ? from avi to mpg ..any information provided is for educational/experimental purposes only.Comment
lv used somthing close but the one l used converted to a file as u watch . so if the converter was slow u would get to a place where u had to wait . so l gave upany information provided is for educational/experimental purposes only.Comment
No it doesn't create a file it just streams it through HTTP (Port 8080 I think)
You should give it a try!
Like I said before I'm not sure if it is compatible with DK images but it should be. Gemini and DK images are both Enigma based aren't they??
I could try to get it from the Gemini server if you'd like?Comment
Heres the plugin's.
the update file in each plugin, will need editing to the DK IMG. (File structure is different) plugin folder
I've zipped them up to a RAR file
1, vlcf.tar.gz
2, movieplayer.tar.gzAttached FilesLast edited by birkenhead; 25 September, 2008, 18:25.Comment
way too complicated
download myvideoconverter
input the converted file to your shared folder and wollah! watch it on your dreambox
fast forward rewind pause. whateverWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
if lm converting a film and watching it seems to stop and start if u know wot l mean , say the conversion takes longer than the film takes to watchany information provided is for educational/experimental purposes only.Comment
OK been playing with this, Installed VLC frontend, you need to install manually and conf is done through the web interface.
errors do show untill web interface is configured
Not getting to far just yet, but haven't the time at present.... got a feeling it need the vlc plugin also.
But i'm having problems getting this to work correctly.
will try again the tomorrow.
Added more plugins
1, VLC.tar.gz
2, Jukebox.tar.gz
just in case some else may want to have play also.Attached FilesLast edited by birkenhead; 25 September, 2008, 22:06.Comment
screw you nag3
Hi all,
I'm not too sure how set up on DK differs from Gemini but if I can help in anyway I can.
When using the Gemini image, once the plugin is installed it is a case of altering the VLCF Original.xml file in var/tuxbox/config (I hope that's the right path! I'm at work so I can't double check)
Once the.xml file is set up to your PC's IP Address and the server set path is altered to look in the correct place on your PC. It is just a case of making sure VLC on your PC is open and setup as per the guide I posted.
Hope this helps! Like I said if I can help I will!!Comment
