anyone in cardiff area
  • dehowletts
    • 35
    DM500 anyone in cardiff area
    Hi peeps
    dbox 500c just gone off EVERYTHING gone whilst watching it any1 else this has happened to??
    any info at all would be good!!
    Thanx in advance
  • dalejake
    • 14
    I am a Cardiff ntl area all chanels gone including fta
    • mlewis7564
      • 7
      Yes I have exactly the same problem, something has obviously just been changed. Anyone know how to fix this?
      I've just done a bruteforce search but all the channels are still down.
      • mlewis7564
        • 7
        Ok, I see what they've done - they've changed all the channels so now the bouquets don't work!
        I went in to the 'Last Scanned' bouquet & most things in there work, one thing I did notice is that different region BBC & ITV channels aren't working.
        Bottom line is you're now going to have to redo all your bouquets. Could have been worse though!
        • dalejake
          • 14
          Cool ill give it a try once I am home and let you know
          • 666
            • 84
            same here no bbc1 got some channals back, but dont no what they done, just doing scan now channel name comes up but on the bottom it saying unknown
            • dehowletts
              • 35
              Hi
              It's not just my bouquets NOTHING's working will FTPing it again right it does any1 know please??
              • dehowletts
                • 35
                Can you expand a bit more on this please mate?
                or pm me if poss??
                what image are you using please?
                • nitro007
                  • 6
                  Hey need help guys any one have the majic file fix for the dbox, using comando image, box just went down!!
                  • nitro007
                    • 6
                    BTW have dbox2.....also cause the boxes are down, does that mean nag 3 has finally arrived?
                    • ManofScience
                      • 650
                      this is stage 1 of N3 implementation. it goes;
                      1) Channels re-organised/NGTV setup/N3 Stream appears
                      << a month or so >>
                      2) New cards start arriving for legit boxes
                      << 3 or 4 weeks >>
                      3) N1 stream turned off, channels gone
                      at the moment, you're stage 1. re-scanning will pick up the channels on their new freqs but you'll have to sort them yourselfs.
                      • dehowletts
                        • 35
                        << a month or so >>
                        << 3 or 4 weeks >>
                        Hi Thanks for the heads up!!!
                        & I've solved the problem resetting box doing bruteforce UK etc didn't work 4 me....
                        THIS DID WORK tho cableUK6887 if any1 else still missing ch's
                        • dalejake
                          • 14
                          had to rescan my dbox as well with commando 11
                          • dehowletts
                            • 35
                            BTW peeps just had to re FTP (2nd time) to get all channels back
                            had to do it twice cos it wants to jump to this one channel called cable0000000000 which got rid of channels again so 2nd time i deleted it as fast as i could seems to have done the trick so far!!
                            any1 else had this happen??
                            also when i try & back-up my back-up's not there any suggestions?
