I recently flashed a 500c, done scan an that, got all channels, only FTA are showing picture and premium is a black screen, i started evocam and still dont work, th eprimium channels have epg data suck as whats on and up next and remaining time just no picture. what have i done wrong?
No premium channels only FTA??
nowt m8 think you need to do a little bit more reading quick clue...........ftp............magic files.............keysI recently flashed a 500c, done scan an that, got all channels, only FTA are showing picture and premium is a black screen, i started evocam and still dont work, th eprimium channels have epg data suck as whats on and up next and remaining time just no picture. what have i done wrong? -
, the keys are in the image already, i go to file mode and can see nagra keys in there, is that correct? thanks
Whats the image,if its from before the last hit,the roms are no good.Checkout the RED stickies massive amount of info and effort been put into them.Comment
No, because the roms are useless,it will roll to an extent but the keys are false.Checkout the RED stickies massive amount of info and effort been put into them.Comment
its dead easy m8 honest or you can use dreambox command centre or flash fxp or anything like that its only a couplde of filesComment
You need to replace these files
Copy contents of Keys folder to /var/keys
Copy contents of Scce folder to /var/scce
RapidShare: Easy Filehosting
And the above are the files you need.Checkout the RED stickies massive amount of info and effort been put into them.Comment
Thanks so much for the help.
Do i delete the files already in the folders?
Also, my other box doesnt get recognised by dreamup, anything i can do?
Thanks againComment
Just delete and replace,as for the other box,is it a cabling issue?deffo a null modem cable and static serial port on pc?usb adaptors are notoriously un-reliable.Checkout the RED stickies massive amount of info and effort been put into them.Comment
i had 4 boxes all new, so i flashed two, prepared connection then put power in and nothing happend, tried a few times and nothing, put 4th box on worked instant like 1st two, maybe have a faulty box?Comment
Try flash wizard pro instead,perhaps the serial ports are knackered?or try another version of dreamup?Checkout the RED stickies massive amount of info and effort been put into them.Comment
