No premium channels only FTA??
  • swiftstyles
    • Oct 2008
    • 32
    I recently flashed a 500c, done scan an that, got all channels, only FTA are showing picture and premium is a black screen, i started evocam and still dont work, th eprimium channels have epg data suck as whats on and up next and remaining time just no picture. what have i done wrong?
  • father ted
    • Feb 2008
    • 1389
    nowt m8 think you need to do a little bit more reading quick clue...........ftp............magic files.............keys
    • swiftstyles
      • Oct 2008
      • 32
      , the keys are in the image already, i go to file mode and can see nagra keys in there, is that correct? thanks
      • father ted
        • Feb 2008
        • 1389
        dont know how there should be keys in the image m8 its illegalthey mite be old ones
        • Donnie Darko
          • 442
          Whats the image,if its from before the last hit,the roms are no good.
          Checkout the RED stickies massive amount of info and effort been put into them.
          • swiftstyles
            • Oct 2008
            • 32
            Hi, yes you are right, its before the last hit, but shouldnt it roll? its dw2.0 maybe, thanks
            • Donnie Darko
              • 442
              No, because the roms are useless,it will roll to an extent but the keys are false.
              • swiftstyles
                • Oct 2008
                • 32
                right i get you, well i have no idea what to do, can i doit without ftp?
                • father ted
                  • Feb 2008
                  • 1389
                  its dead easy m8 honest or you can use dreambox command centre or flash fxp or anything like that its only a couplde of files
                  • Donnie Darko
                    • 442
                    You need to replace these files
                    Copy contents of Keys folder to /var/keys
                    Copy contents of Scce folder to /var/scce
                    RapidShare: Easy Filehosting
                    And the above are the files you need.
                    • swiftstyles
                      • Oct 2008
                      • 32
                      Thanks so much for the help.
                      Do i delete the files already in the folders?
                      Also, my other box doesnt get recognised by dreamup, anything i can do?
                      Thanks again
                      • Donnie Darko
                        • 442
                        Thanks again
                        Just delete and replace,as for the other box,is it a cabling issue?deffo a null modem cable and static serial port on pc?usb adaptors are notoriously un-reliable.
                        • swiftstyles
                          • Oct 2008
                          • 32
                          i had 4 boxes all new, so i flashed two, prepared connection then put power in and nothing happend, tried a few times and nothing, put 4th box on worked instant like 1st two, maybe have a faulty box?
                          • Donnie Darko
                            • 442
                            Try flash wizard pro instead,perhaps the serial ports are knackered?or try another version of dreamup?
                            • swiftstyles
                              • Oct 2008
                              • 32
                              thanks ill give that ago today
