PLi - Scanning for services
  • thered
    • 4915
    #16
    well good luck m8 im off to bed now
    • westkill
      • 2378
      #17
      if your using a splitter do a scan of the main feed first then replace the splitter and see what channels work ok
      • mercenary
        • Jun 2009
        • 48
        #18
        i keep scanning and get not one service. is there settings im missing? any tuner settings?
        • Curious123
          • 2591
          #19
          I would get rid of the booster altogather as I am sure too much signal is just as bad as too little signal. Have you tried copying the latest cables.xml file to var/etc folder and then doing a scan?
          • mercenary
            • Jun 2009
            • 48
            #20
            i dont have a booster, i have the pli image , i have cables.xml in /var/etc which is linked to /var
            where can i do a bruteforce scan?
            • mercenary
              • Jun 2009
              • 48
              #21
              executing main
              setIoPrio best-effort level 3 ok
              couldn't open fp
              enumerating block devices...
              found block device 'mtdblock3': blacklisted
              found block device 'mtdblock2': blacklisted
              found block device 'mtdblock1': blacklisted
              found block device 'mtdblock0': blacklisted
              found block device 'hda': ok, removable=False, cdrom=False, partitions=['hda1'], device=hda
              couldn't read model: [Errno 2] No such file or directory: '/sys/devices/pci0000:01/0000:01:00.0/ide0/0.0/model'
              new Harddisk hda -> /dev/discs/disc0/ -> /dev/ide/host0/bus0/target0/lun0/
              [ePopen] command: ('hdparm', 'hdparm', '-S0', '/dev/discs/disc0/disc')
              found block device 'loop7': blacklisted
              found block device 'loop6': blacklisted
              found block device 'loop5': blacklisted
              found block device 'loop4': blacklisted
              found block device 'loop3': blacklisted
              found block device 'loop2': blacklisted
              found block device 'loop1': blacklisted
              found block device 'loop0': blacklisted
              main thread is non-idle! display spinner!
              Preferred tag editor set to None
              NOT reading cables.xml
              why isnt it reading my cables.xml where must i store it?
              • westkill
                • 2378
                #22
                what town area do you live in m8
                • mercenary
                  • Jun 2009
                  • 48
                  #23
                  ealing london
                  i have tried a manual scan, my box just doesnt like it
                  • westkill
                    • 2378
                    #24
                    Originally posted by hogansghost
                    In the "service Scan" page it says ;
                    Tuner - Tuner A DVB-C
                    Type of Scan - Single Transponder
                    Frequency - xxx
                    Inversion - Auto
                    Symb Rate - 06952
                    Modulation - 64-QAM
                    FEC - Auto
                    Network Scan - Yes
                    Clear Before Scan - No
                    Only Free Scan - No
                    Frequency is first 3 digits of local "5-digit" frequency
                    When press "OK" it says ;
                    DVB-C QAM64 415000 / 6952 / AUTO
                    Returns no services found.
                    use whats here but make the frequency 642 or 642750 if the option avalible
                    might work
                    • mercenary
                      • Jun 2009
                      • 48
                      #25
                      no luck, its wierd my tuner only picks up via bruteforce and i cant do it. every now and then on certain images it allows me to use a cables.xml, but i want to use PLi
                      • mercenary
                        • Jun 2009
                        • 48
                        #26
                        its now working, i dunno how but im happy,
                        PLi Image
                        scanned 401 channels
                        thanx to everyone on the board
                        • Curious123
                          • 2591
                          #27
                          Good to see you got yourself sorted.
