dreambox 7025 HELP
  • remakable
    • 55
    dreambox 7025 HELP
    HI
    I'M STUCK I HAVE 7025+ AND I HAVE CABLE AND SAT TUNER INSTALLED WIHICH IS THE BEST IMAGE FOR BOTH TUNERS WHICH HAVE THE UK CABLE TRANSPONDERS INSTALED ALREADY ALL I HAVE TO DO IS FTP THE CABLE XML FILE
    PLEASE HELP ADVICE
  • thered
    • 4915
    i dont know if any have the cablexml built in i have a 7025 running with gemini ok
    i dont really see much difference in any image too be honest i have tried a few pli LT oozon,nabilo apart from a different skin they are all pretty similar
    • remakable
      • 55
      hi
      I HAVE NO PROBLEM WITH THE CABLE XML
      IM STRUGLING WITH THE CABLE TRANSPONDERS LIKE BRUTEFORCE I DONT HAVE ANY OF THEM IN IMAGE SO I CANT SCAN ANY THING. WHICH IMAGE SHOULD HAVE THE BUILT IN TRANSPONDER FOR THE CALE.
      • remakable
        • 55
        HI
        CAN SOME ONE PLEASE HELP SCANING THE CABLE CHANNELS ON MY 7025+.
        • westkill
          • 2378
          you will have to do a manual scan for cable were do you live m8
          • remakable
            • 55
            HI
            I LIVE IN READING BERKSHIRE
            • westkill
              • 2378
              so do i m8
              type of scan >single transponder
              frequency > 803
              inversion > auto
              symbol rate > 6887
              modulation > 64 qam
              fec > auto
              network scan > yes
              you might have this option
              clear before scan > no
              free only > no
              what image you using m8
              • remakable
                • 55
                hi
                I'M USING OOZOON FULL. DO YOU RECOMMEND ANY OTHER ONES ARE GOOD. FOR BOTH TUNNERS SAT AND CABLE. I WILL TRY THIS NOW.
                • remakable
                  • 55
                  hi
                  i done the scaning
                  ftp the cable.xml
                  now can some tell me what else do i need im gessing an emu, if thats correct how do i put that on the box
                  • remakable
                    • 55
                    hi
                    cme on ppl
                    • Curious123
                      • 2591
                      Not all of us can afford a dm7025 so you have to expect the limited response. On my dm600 I always load the emu with the Blue button on the remote and download the cam from the image makers download servers. Which are you using ?
                      • remakable
                        • 55
                        hi
                        im using gemini 3.70 how can i clear the cable channels please help.
                        • felix1
                          • 211
                          u need to import the files with the keys/roms ect. should be in the download section. them your emu from the blue panel. download a few to se which work im not sure as i dont use cable any more.
                          once youve done your scan for cable and activated the emu (mgcam i think or evocam) you should see something. (as long as you have the key files).
                          with sat you may be beter off using cccam (so make sure youve down loaded that too)
                          when you switch between cable and sat you may have to change emus (unless one works for both. no idea as i dont use cable anymore).
                          that should be it.
                          check out the tutorials the principles the same for all the boxes.
                          HTH
                          • remakable
                            • 55
                            hi
                            i'm so pissed off i have been ****ing around with this box all night and im about to give up on it,
                            i have done every thing possible that i could im feel like jump of the cliff with this box.
                            • felix1
                              • 211
                              no need to over react m8. no need to take the box when you jump.
                              find a good tutorial. its really not that hard. although if youve had experience of linux boxes before it does help.
                              use google im sure you will find the right tutorial. if theres not one here already.
                              (not sure about links to other sites here so dont wanna break any rules)
                              and if you do decide to jump leave the box in your will for me PLEASE.
