dreambox 7025 HELP
  • remakable
    • 55
    #16
    hi
    trust me i have tried every thing
    ftp the new roms
    evcomd 2.17
    mgcamd 1.31 run them both,
    changed the new roms 7,10,11
    got all the files for the keyfolder.
    waited 20 minutes.
    nothing in the hell is happining
    i have been doing dm500c for a long time but this mf ft me over 6 ways
    • westkill
      • 2378
      #17
      are you using the gemini image i sent you m8
      i think all you had to do is goto blue panel and start restart mg camd or evocamd what was loaded on the image
      • westkill
        • 2378
        #18
        or ftp to usr/ and delete the keys and scce folders and do the same in var/
        then ftp to usr/ and put these keys and scce files in then restart the box
        then to blue panel and start /restart the emu
        go here to get the rapid share link with files
        • remakable
          • 55
          #19
          hi
          thousands thanks finally i got it up and running i couldnt be more happier.
          • remakable
            • 55
            #20
            hi
            i have done the cable now im around to satellite side i know i have setup usals properly i will scan some satellite if there any thing i need to know please direct im sure this thread will help alot of people.
            • remakable
              • 55
              #21
              hi
              i got mgcamd is runing clearing cable i have problem i can record but when i go to the media player i can't playthem the files are in my internal hardrive.
              any help guys
              • westkill
                • 2378
                #22
                press the video button and it will bring up the list of recordings
                no need to go into media player
                • remakable
                  • 55
                  #23
                  hi
                  thanks guy i had to install the plugins from the server for the media player now i can watch them n record.
                  now i need to get into sat side i have installed the diseq motor sucessfully and i have sated up on usals just scaned astra 19.e now wat do i need to clear them
                  • westkill
                    • 2378
                    #24
                    yo need to merge some sat keys and scce folders with your cable ones
                    • thered
                      • 4915
                      #25
                      dont think you will clear much on 19 east m8 thor at 0.8 west is your best bet at the minute with keys
                      • remakable
                        • 55
                        #26
                        hi
                        i got this rarfile call eagle keys, its got two folder one is keys and one is scce do i ftp the folder or shell i copy the contents of these folders and past it into the folder that already there.
                        • thered
                          • 4915
                          #27
                          add the keys as you would the cable keys
                          just rename autoroll and autoupdate anything will do as long as you remember it
                          copy and paste the text from the softcam.key file of your cable keys and your keylist text into the same folders of your eagle keys
                          once you have added you keys just overwrite any existing ones change your autoroll and autoupdate files back to normal but this time just use lowercase letters NO CAPITALS
                          this will give 2 autorolls and 2 autoupdates the only difference is the capital letters
                          • cassie
                            • 5
                            #28
                            Anychance of a copy of that image please, and the frequency for manual scan in pure notts.
