I think I know why some of us arn't getting this channel
I got a 500c which is 2 years old and won't pick up sly1
I just flashed a mates 500c which is 3 months old and has a screw tuner.
Mt mate picks it up but mine won't
I even tryed the service number via tuxbox, the 1:0:1: ....... number and no luck.
Looks like the older boxs can't pick up transponder 19
i got my areas services file and now all missing channels are there including sly1
so the missing channels couldnt be detected while manual / automatic scanning but using the services file they all work 100% with over 90% signal strength - weird huh
You need a good signal to pick up sky1.. using splitter I can't find it with DM500c or DBOX2, Without splitter it picks it up on both while scanning. I think it's a signal issue.
that happened to me a few months back.
When you do the bruteforce scan slyone comes back (but not in your bouquet) it comes back with a ! at the end (haven't a clue why). But you have to delete the one you can't see from your favourites and then add the slyone! from "all services" to your specific bouquet
hope this helps
I have not heard of this services file could you explain it to me and what to do. would appreciate any help you can give me
rockinbob
