no sly one
  • trickykid
    • 89
    #16
    Originally posted by rockinbob
    I have not heard of this services file could you explain it to me and what to do. would appreciate any help you can give me
    rockinbob
    i suppose he's referring to cables.xml file...
    • shady77
      • 982
      #17
      Originally posted by saj1985
      btw how do i get rid of the '!' sign at the start of a channel???
      highlight channel, press menu, then remove "new found" flag
      • saj1985
        • 785
        #18
        cheers mate!
        Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
        • hashleyf
          • 44
          #19
          no
          the "services" file in var/tuxbox/config/enigma
          its a file which has the tuning info for channels in (the correct enigma = "services" / for neutrino its "services.xml" - you can use bouquetter to convert between the 2 formats its dead simple guide here > http://www.digital-kaos.co.uk/forums...a-services-36/ )
          if you can get hold of a service file for your area, copy it to
          enigma = /var/tuxbox/config/enigma
          neutrino = /var/tuxbox/config/zapit
          then
          Open web browser and paste the following command into the address bar:
          (replace x with the dreambox ip address)
          more detailed information is here
          • rockinbob
            • Oct 2008
            • 39
            #20
            Originally posted by hashleyf
            no
            then
            http://www.digital-kaos.co.uk/forums...bouquets-7124/
            thanks alot for all of your help will give it a try after the turkey has gone down
            • lacabbie
              • 6
              #21
              Sly 1
              The frequency for sly 1 in the plymouth area is 843000 for a manual scan
              • hashleyf
                • 44
                #22
                yeah the biggest problem seems that if you have a old tuner in the dreambox - no matter how many manual / auto / full scans are done it just refuses to pick up sly1 and a couple of other channels
                • mikeyb
                  • 161
                  #23
                  not technical but I would agree, I just can't get the discovery channels working. I think I just need a signal booster.
                  • rockinbob
                    • Oct 2008
                    • 39
                    #24
                    thanks for your help i think i am on a old tuner
                    • mikeyb
                      • 161
                      #25
                      Can you change the tuner in a dreambox? This might be an excuse for me to buy a new box
                      • bugaloo41
                        • 1598
                        #26
                        yes but its much easier and almost just as cheap to buy a new box. your problem looks like it would be solved by a booster.
                        • hashleyf
                          • 44
                          #27
                          discovery isnt working as in you cant find them in the channel list after a scan? or as in they are there but black?
                          If its the first of those 2, just try and find someone in your area who can give you a "services" file and you might find it all works - thats how my sly channels were fixed
