Tutorial on how to enter keys.
  • cgscott
    • 3513
    DM500 Tutorial on how to enter keys.
    Providing you have the dk image you press the blue button then select tubox commander.
    Then scroll down and select var then keys then keylist.txt.
    This is where the keys go.
    You will notice depending on your provider 2 lines that start with 5a or 54
    5a is telewest and 54 ntl.
    Now the codes you get with keymater have to be manually input through tux.
    so select edit the only put the numbers in the appropriate place.
    For example. 5401 00 then code
    5401 01 then code
    Save and exit pull the plug on your dreambox the it should be fine.
    I couldnt put this more simple.
    PS. If your using the DW image its the yellow button to enter tux commander.
    Please read through and try.
    Any other boxes with tux has the same principle.
    Patience is a virtue.
  • harry1986
    • 516
    weldone cgscott excellent infomation explained about in putting keys for everyone
    • mo.p
      • 298
      5401 01 then code
      hi m8 i scroll down and select var then keys then keylist.txt then i cant edit keys any more help plz its dk.1
      • theloanman
        • 9
        help my keys dissapeared!!
        i followed your guide..cool..rebooted.. all ok then checked the keys again and they had all dissapeared!!! what has happened and how can i input the keys again cos i press 4 and nothing happens????? please help!! im crushed after thinking id sussed it out :[ btw i tried to turn off autoupdate but theres nothing in this field either???
        • cgscott
          • 3513
          Go down the ftp route.
          exact same process except it through a ftp program.
          I use dcc which can be found here.
          Digital Kaos - Downloads - Dreambox Forever
          Everything you need to make your box better
          • kwasiarsenal
            • 30
            Hi everyone,
            Any help for those with DM7025. I have got a sc tuners and the cable chls are gone. got the KeyMaster and Dreambox Forever with LT or Newnigma image. Where do I start?
            Thanx;;
            • kwasiarsenal
              • 30
              Hi,
              I have managed to find the key manager on the Newnigma image and can see 5401 00 and 5401 01, but the keymaster has many key codes for different area, which is the uk ntl? Please;;
              • nightmark
                I was wondering the same. std virginn media is not on list, anyone know them for Laky Pro
                • sman112
                  virgin media used to be known as telewest (TW) so use them codes it
                  • Jaffa
                    • 1612
                    Originally posted by kwasiarsenal
                    Hi,
                    Pure keys is standard NTL/VM
                    There are loads of different areas, if you post what area it may be possible to say for sure which one syou need
                    • Ballistic
                      • Oct 2008
                      • 243
                      Hi,
                      Well i would try them all, starting withe Pure
                      B
                      "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
                      • clit-eastwood
                        • 339
                        depends what area...if you are in an ex ntl area tw keys wont work....use pure keys for ntl
                        • theloanman
                          • 9
                          ive managed to get the box connected to my lappy through the router and ftp but there are so many options im totally lost on how to get access to the key.txt any help would save the dog fm a good kickin heh p.s. it says bootmanager not found??? is that important?
                          • theloanman
                            • 9
                            no..its cool...i found it :] x ure fingers all hehe
                            • theloanman
                              • 9
                              omg it keeps changing the new key i put in wen i reboot goddamnit i gotta turn autoupdate off now :[
                              as i thought it was set to 01 man im learnin a lot tonite...:]#
