help need flashing tutorial for commando 12on 500s
looking for flashing tutorial commando 12 for DM500s
where CCcam goes and where config file goes
all help appreciated
Haven't tried Commando on dreambox so I can't be much help.
Because image has been modified for dream I'm not sure.
On D-box cam goes in var/bin/emu [chmod to 755] & conf. goes
in var/keys.
On Dream using DK 1.1 image cam goes in var/bin, & conf. goes
in var/etc.
Have a look in folders on dreambox after you flash Commando &
ftp cam & conf files to same folders as existing cam & conf.
You could also check list of internet add-ons in Commando. If Ccam is on list it will auto-install files in correct folders.
If you have Ccam in var/bin & Ccam. cfg. in var/etc. you don't
need any other files to enable c-line.
In Ccam/conf. go to any empty line, delete # and enter c-line
