help need flashing tutorial for commando 12on 500s
  • chazt
    • 166
    looking for flashing tutorial commando 12 for DM500s
    where CCcam goes and where config file goes
    all help appreciated
  • EAMO 2
    • 1201
    Haven't tried Commando on dreambox so I can't be much help.
    Because image has been modified for dream I'm not sure.
    On D-box cam goes in var/bin/emu [chmod to 755] & conf. goes
    in var/keys.
    On Dream using DK 1.1 image cam goes in var/bin, & conf. goes
    in var/etc.
    Have a look in folders on dreambox after you flash Commando &
    ftp cam & conf files to same folders as existing cam & conf.
    You could also check list of internet add-ons in Commando. If Ccam is on list it will auto-install files in correct folders.
    • hearts
      • May 2010
      • 96
      I have it with CCcam installed. Flashed using Dreamup. Nice image I like it a lot. ;-)
      CCcam.cfg is in var/etc just add your cline.
      • mackin
        • 5
        And were do you put the rest of the files?
        Struggling to get Cccam working,
        • EAMO 2
          • 1201
          If you have Ccam in var/bin & Ccam. cfg. in var/etc. you don't
          need any other files to enable c-line.
          In Ccam/conf. go to any empty line, delete # and enter c-line
          • mackin
            • 5
            I thought CCcam went into var/bin/emu ?
            I also have the following files within the zip file i downloaded.
            CCcam.armeb
            CCcam.armeb.eabi
            CCcam.cfg
            CCcam.mipsel
            CCcam.ppc
            CCcam.x86
            CCcam.x86_64
            Do i need to FTP all these files to var/bin/emu ? and then chmod them all to 755?
            Thanks in advance.
            • mackin
              • 5
              Sussed it at last.
              I FTP'd Cccam.ppl to /var/bin/emu then renamed to just Cccam and chmod to 755
              I then placed my Cccam.cfg into /var/etc and also chmod 755.
              All now works
              • EAMO 2
                • 1201
                Sussed it at last.
                All now works
                You done very well, didn't think you had to chmod cam/cfg.
                Did you use Cccam 2.13 or some other cam
                • mackin
                  • 5
                  CCcam 2.14 is the version i used.
                  Not sure if i needed to chmod the cfg file, think i just did to make sure all would work.
