HELP PLEASE!!!
  • s411ota
    • 49
    HELP PLEASE!!!
    My dbox 500 is driving me mad now, flashed a new image off another site with the new fix via a null modem cable to no avail.
    So now been pulling my hair out trying to FTP the new fix.
    This is my set up:
    Wireless router- Netgear IP address 192.168.0.1
    Laptop - connected to net via wireless connex to router - IP 192.168.0.2
    Dbox - plugged into main and ethernet cable from the back of dbox into a free port into the back of the router.
    Boot up FLASHfxp and input the IP of the dbox which i got when it was connected to the tv through the expert setup menu etc as 192.168.0.24
    username:root
    password:dreambox
    when i press connect all i get is Connection failed.
  • bugaloo41
    • 1598
    Mate I think your ip address of the box could be out of range.
    Change the address of the box (just use the remote to do this) to 192.168.0.3 and try again.
    • s411ota
      • 49
      the remote will not highlight the ip addy of the box it only moves to the tick box DHCP, LAN, enable netwrok, save and mounts
      • bugaloo41
        • 1598
        Remove the tick from DHCP and reset it after that mate.
        • Curious123
          • 2591
          Forget flashxppro seen so many people have problems. Download a proggie called Coreftp and use that to ftp files to your dreambox. It works just like Windows explorer so pretty easy to master.
          • s411ota
            • 49
            ok worked a treat, you is good.
            let me now trying plugging into router and seeing if flash picks it up
            • s411ota
              • 49
              nope
              still getting connection failed
              • s411ota
                • 49
                problem is, no matter what i try, filezilla/flash.. i am not getting any connection
                do i need to plug my laptop via ethernet to the router aswell? even though its wirelessly connected to the router.
                • bugaloo41
                  • 1598
                  Do you have a crossover cable running from your laptop to your dreambox because that what you will need to get them talking to one another. Alternatively you can use a patch or crossover cable running from your router to the dreambox but you must have them rigged up with a cable.
                  • skunk1111
                    • 55
                    link yer pc ..laptop what ever direct to yer box...
                    remove the router.
                    • Curious123
                      • 2591
                      If he removes the tick than he needs to give it a static ip address. Have you tried pinging the ip address of your dreambox?
                      • s411ota
                        • 49
                        no crossover from laptop to dbox
                        but i have a cross patch plugged from dbox into back of router
                        this is honestly nuts...losing the will to live.
                        • s411ota
                          • 49
                          i removed the tick, chanded the ip addy and then reticked the DHCP box
                          • bugaloo41
                            • 1598
                            Your problem is that you have no cable connection between your laptop and dreambox. Given that you have a connection from your router to the dream why dont you ftp via your pc (or am i missing something?) What you have done with your address is fine.
                            • s411ota
                              • 49
                              but if i am connected to the router ( laptop is ) wirelessly and then the dbox is connected to the same router via a ethernet... is that not a connex?
