I have the same problem, supplier hasnt given a pin code any help? same box (blackbox 500)
Blackbox 500c setup pin?
Black Box 500
Same problem here... Cannot access ftp with the default credentials. Any idea how to restore the receiverComment
There is no way u can reset the setup pin unless u r able to ftp to yr box. Reflashing is yr only solution but u will lose all settings and only fta channels will be viewable.Comment
If all the login in attempts fail and you dont have the password. Use dreamup to flash the dreambox. Every thing will be reset to default. Follow procedure given at :
http://www.digital-kaos.co.uk/forums...ox-dreamup-33/ to reflash. There is no other choice.Comment
A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
No I dont think so
You got to seek help from experts in your area. I am only familiar with images for Singapore.
Over here we need the key and rom files to be able to watch all those encrypted channels.A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
Hi DBTraitor,
This is Ash,, not sure you remember me, tried to PM you but is blocked, can you contact me tks..Comment
