cable and satellite
  • s23pho
    • 61
    cable and satellite
    hi there, do you treat cable and satellite the same, or are there seperate images and bouquet lists
  • EAMO 2
    • 1201
    Totally diff signals so need diff tuners as in DM500c is for cable
    DM500s is for sat.
    Some images such as DK1.1 or PLI-Jade500 will do for cable or
    sat. Other images are for either cable only or sat only
    There are diff bouquet lists for cable & sat
    • s23pho
      • 61
      thanks, is cable still up and running, i.e you can still get all channels or has n3 'solved' that issue? Also not to be a pest and i have done my own research, but i still dont understand where you get the channel lists from to watch all channels on cable. Thanks Steph
      • EAMO 2
        • 1201
        Cable dreambox cannot clear N3 channels. If you have proper
        image like DK1.1 you just select your location & scan for channs
        You then organise channels into any bouquets you wish or you
        can look thru bouquets list in DOWNLOADS to find your area
        Digital Kaos - Downloads - Services and Bouquets
        • s23pho
          • 61
          so is it possible to watch sky uk through cable? or should i go with satellite, thing is i already have cable fitted in my house. Thanks Steph
