could not connect to server
  • laguna35
    • Oct 2008
    • 47
    DM500 could not connect to server
    anyone help pls using flashxp to upgrade dm500. connected via laptop using crossover ethernet cable. put right ip address in site manager but it keeps saying could not connect to server. i'm stuck
  • Ballistic
    • Oct 2008
    • 243
    Ho have you connected everything...I go Box to Router with ethernet and then wireless connect via ftp to Box? works for me
    Double check the ip address and that DHCP is enabled in the communication set up page.
    B
    "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
    • laguna35
      • Oct 2008
      • 47
      ip address ok. so i connect cable tp router. what do i do next. sorry for being thick but i have a euromax. trying to do this for friend
      • durtyballs
        • 7
        wat is ftp
        • Ballistic
          • Oct 2008
          • 243
          Your not being thick at all mate, I have never connected straight to box with pc using ethernet so I dont know that way only what i have read... must try it really to see if i can
          I added to my reply above about the DHCP being enabled...maybe thats the why it wont connect.
          B
          • durtyballs
            • 7
            im havin the same prob. do i connect my dreambox to my router with patch lead and is thta it
            • laguna35
              • Oct 2008
              • 47
              on DHCP do i put a cross in the box
              • Ballistic
                • Oct 2008
                • 243
                Originally posted by durtyballs
                wat is ftp
                means - File Transfer Protocol
                Basically its when you transfer files from on place to another...in this case your pc to the Dbox... usually you use a program like flashxp ...theres loads of them out there...Once its connected and open you have two windows ...one for each item you are connected to and then you select what ever you want to move from one to the other and either upload or download it.
                HTH
                B
                • Ballistic
                  • Oct 2008
                  • 243
                  Yes that would mean its enable..give it a go
                  B
                  • Ballistic
                    • Oct 2008
                    • 243
                    Thats the way I do it.....
                    Router - DB with ethernet
                    Then i use the pc to wireless connect to Db usinga FTP ..I use one called Transmit but if you go through the red stickie guides theres others in there that can be downloaded and used.
                    B
                    • laguna35
                      • Oct 2008
                      • 47
                      connected box to router with crossover ethernet
                      Communication Set up as follows
                      IP 192.168.0.100 DHCP cross in box
                      Netmask 255.255.255.0
                      Type Lan
                      Nameserver 192.168.0.100
                      Gateway 192.168.0.100
                      Enable Network cross in box Port 21
                      still cant connect to server
                      • Ballistic
                        • Oct 2008
                        • 243
                        Type Lan
                        Yeah you've changed the wires to how you had it. I suggested ticking the DHCP if you were going straight from Box - PC as thast how you had it ..
                        No worries as you have the box connected to router.
                        Fire up your pc and ftp program and connect that way..
                        ip address
                        userid:root
                        password: dreambox
                        Got to pop out , hopefully you will get connected, or someone else will be along to help
                        B
                        • laguna35
                          • Oct 2008
                          • 47
                          thanks for you help ballistic going to fire up desktop and try with that. wiil let you know
                          • Devilfish
                            Administrator
                            • Feb 2008
                            • 7872
                            Do you know your router ip address? This is the address that you put in your browser to access the web interface (to set up wireless, etc.). Put the router ip address in the default gateway section of the network settings page, enable DHCP, save and reboot the box. Now go back into the network settings page and see what ip address the router has assigned the dreambox. Use this ip address in your ftp program to connect.
                            • laguna35
                              • Oct 2008
                              • 47
                              top man ballistic thanks very much
                              and thanks to devilfish very much apreciated
