DM500 CII (INSERT SMART CARD)
This topic is closed.
  • ypvs125
    • Dec 2010
    • 506
    #61
    Originally posted by rogertoh16
    Anyone can send me the file as well? Thks
    Did u mention about which box r u using? More info needed.
    • Malayguy
      • Dec 2011
      • 4
      #62
      Originally posted by reddy
      I experience this once, you need to go to menu>setting>>load default. you'll be prompt set will reset. click on ok and the set will reset. Thereafter, you'll need to rescan all channels and you'll get all channels back again.
      Not sure if that'll help you, but it worked for me..
      Mine after scan still the same
      Last year I enter the long digit password after that then can get now that password use still cannot get
      • reddy
        • 37
        #63
        Check PM. See if it helps.
        • Malayguy
          • Dec 2011
          • 4
          #64
          It works!
          Thanks a lot!!!! Haha
          • tester99
            • Dec 2011
            • 4
            #65
            Dear Bros.
            Initially I can watch all channels, then one day only half of the channels, and finally last sunday, I am unable to see any channels from the box.
            Can anyone help me please?
            Thanks in advance!
            • ypvs125
              • Dec 2010
              • 506
              #66
              Originally posted by tester99
              Dear Bros.
              Thanks in advance!
              If yr set is using the card and u can see fta channels only, yr card could have expired.
              • mutabak
                • Feb 2011
                #67
                dm500cii and dm900c some channels are gone. anyone can help?
                • tester99
                  • Dec 2011
                  • 4
                  #68
                  Hi, thanks for your reply.
                  Mine do not have any card in the set. I am from Singapore and using it to watch SCV channels.
                  I have previously key in some codes when the channels were not watchable. But after I keyed in some codes, am only able to see some channels. But since last two days, I am unable to see any channels. Is that any new codes to key in?
                  Thanks.
                  • tester99
                    • Dec 2011
                    • 4
                    #69
                    I am using DM500 C-II. There is no card inserted in the set. I tried some method posts by the bros here to load the default profile and followed by autoscan but still getting the "insert smart card" error. Unable to see sta*hub channels now.
                    I missed "Kang Xi Lai Le".
                    Can anyone post me new codes if any or help me to resolve this?
                    Greatly appreciated. Thank you.
                    • duriantreetop
                      • 36
                      #70
                      If your box is cardless firmware, it should not prompt you to insert card. It has nothing to do with code or keys. Please check with your supplier. No image in this forum support your box.
                      • reddy
                        • 37
                        #71
                        Bro, See PM.
                        • tester99
                          • Dec 2011
                          • 4
                          #72
                          Bro, See PM.
                          Dear Bro Reddy. Greatly Appreciated.. It worked.
                          I am able to see all channels again.
                          • mutabak
                            • Feb 2011
                            #73
                            Bro, See PM.
                            bro, please pm me as well. thanks.
                            • reddy
                              • 37
                              #74
                              Bro,
                              Check PM to see if it helps.
                              • dreamvalour
                                • Dec 2011
                                #75
                                dm500cii
                                can pm me the code too? mine is dm500cii, thks
