DM500 CII (INSERT SMART CARD)
This topic is closed.
  • dreamvalour
    • Dec 2011
    #76
    I'm a noob facing the same problem as the rest of the friends here using DM500-C-II. I don't even know where to begin with. Can you please pm me some of the instructions? Seriously need some help here.
    Thank you very much in advance!
    • reddy
      • 37
      #77
      See Pm. Please click on Thks button if it helps.
      I'm sure it will.
      • ypvs125
        • Dec 2010
        • 506
        #78
        Originally posted by reddy
        See Pm. Please click on help button if it helps.
        I'm sure it will.
        Bro, help button don't have. Only the thanks button.
        • reddy
          • 37
          #79
          haha!!!,Thks for highlighting bro!!.. Yeah, Thks button!!...
          Never notice if u never point out..
          • lem0nee
            • Jan 2012
            #80
            Hi...
            I'm also a noob when it comes to technical problems...i'm facing the same problem (Please insert Smart Card) as the rest of the friends here using DM500-C-II.
            Can you please pm me the instructions?
            Really appreciate your help.
            Thanks so much!
            • lem0nee
              • Jan 2012
              #81
              Hi,
              Anyone kind enough to PM me the instructions?
              Thanks Thanks!
              • reddy
                • 37
                #82
                Originally posted by lem0nee
                Hi,
                Thanks Thanks!
                See PM. It should be able to help you.
                • ip650123
                  • Jan 2012
                  #83
                  Hi all
                  am VERY new....flashed my box, but need a info sheet on how to set up these sharing codes and so on...Can one get a code from anyone....live in sweden with sky. Just got a dm500s and trying my luck...so far so good but need sharing info ...cheers
                  • choujohn
                    • Jan 2012
                    #84
                    Hi, my DM500C ,using NagraVision card with King TV label in it,unable to watch all channels,any kind bros can help?
                    Any way to convert it to cardless with auto key? Appreciate if any expertists can PM me the instruction . I'm from Sg.Thanks .
                    • Nicholasleong
                      • Feb 2012
                      DM900
                      Hi all,
                      I'm unable to see any graphic when I switch on my box. Is there any ways to resolve it? I have tried keying pw 9701 but it can't seem to work too.
                      Thanks for your help
                      • ahbenghero
                        • 32
                        #86
                        for those china imitations (excluding "hk" set, only for dm900cII to dm500cVI) if you encounter "insert smart card"..
                        Try do a automatic quick scan and restart your set after that..
                        If still cannot, try to key in your key 00 and key 01 manually...
                        How to go into the manual key update menu...just key in 9701 using your remote control, it will bring you to the manual key update menu...
                        please take note its only for the cardless boxes...those boxes with cards needs to either get your card updated or buy new cards.
                        • Blurlikesotong
                          • Feb 2012
                          #87
                          DM 500C II unable to work!
                          Hi, I juz got my DM500C II. Was told that it doesn't need to do anything on the set up. Juz connect n play..
                          But the set I got is unable to screen any channel.
                          It only shows the list of channels. But the error message says 'No data'
                          I've tried scanning, but failed.
                          Can anyone help me???
                            I would get in touch with whom you bought it from m8 welcome to the forum.................
                            • Blurlikesotong
                              • Feb 2012
                              #89
                              To add on, the set can works in my brothers house.
                              So why my house can't?
                              • upguy
                                • Mar 2012
                                im having problems with my dm500cII.. initially able to view many channels, now ..most channels are not viewable. Did a re scan but to no avail.
                                Can anyone assist in giving the code ?
