using commando only get FTA channels
thank you for this post worked for me as wellhi, i solved my problem (only getting fta channels) basically the firmware didnt like my cam so (evocamd) so i disabled that and added another and the channels started working (i clicked onto a random channel that wouldnt load then restarted the new cam ... did this for two or three channels then they all popped up) hope this info helps somone. also thought id add that i upgraded frm sportster 1.7Comment
Commando 10 image
Hi Guys,
I've flashed the image, uploaded the keys to the correct sections. i'm just lost at the cam and evocam bit. I know that I am close to completing this, but just need some help with the final bit to remove that damn black screen....LOL
Any help would be truly appreciated. Please PM me the finals stretch, or point in the correct direction.
Almost there,
TonyLast edited by Tonysense; 17 January, 2009, 14:08.Comment
I found with the commando images you have to leave it on s** sports 1 for about 20min for the cams/keys to work.
Still new to this lark, have tried to get the jist of what to do by reading this thread but still clear as mud!
methinks I just need a cam file ... I have an old sportster image will that one do?
Good news is I know how to ftp/telnet and have some unix skills yahhhhay!
Do I also need then an ip address setting in my network tcp etc - if so what should I use?Comment
u can ftp between box and pc?Still new to this lark, have tried to get the jist of what to do by reading this thread but still clear as mud!
hi,i am having the same problem atm were do you get theses files from and how do you connect to the dbox via ftp?Comment
only fta channels afetr image flash
hi, i have flashed new commando image,howver i am getting only FTA channels,its seems like i have lost keys and emus while ftping,when i tryed to scan there is no net id and frequency does anybody know,i live in sunderland
please helpLast edited by arpan10; 29 May, 2009, 00:03.Comment
PAUL
