Trouble with FTP
  • espesso
    • 15
    Trouble with FTP
    I've had the same kind of probs as Validus, can't ftp my box using either cross over ( pc to pc ) or direct via my router. Had to flash image via null modem using the tut from Aftermath ( worked a treat one of the best I've read), but I've still got to load the missing files. Can this be done using null modem cable? I've followed the advice given to Validus, when I test network now dbox is reachable (ping) but gateway and server isn't. Any ideas? 3 days and losing the plot!!
  • MetMan
    • 1091
    did u check ur pc settings using the command prompt> ipconfig /all when using router - can u post these
    • espesso
      • 15
      ip 192.168.2.2
      sub 255.255.255.0
      dg 192.168.2.1
      dns 62.31.176.39
      • MetMan
        • 1091
        ip 192.168.2.2
        sub 255.255.255.0
        dg 192.168.2.1
        dns 62.31.176.39
        on the dbox
        dbox-settings - network
        IP Address 192.168.2.4
        Default Gateway 192.168.2.1
        DNS Server 192.168.2.2
        press Start/restart network now
        then Test network now
        see how many pings u get
        • espesso
          • 15
          ip reachable (ping)
          others unreachable
          • MetMan
            • 1091
            ip reachable (ping)
            others unreachable
            what os vista?
            using a staight network cable?
            can u ping from pc to dbox?
            comand prompt >ping 192.168.2.4
            • espesso
              • 15
              Win xp
              straight
              can't ping
              • MetMan
                • 1091
                Win xp
                straight
                can't ping
                xp normally straight forward....are the settings ur changing on the dbox still there after a reboot?
                the img hasn't gone read-only has it?
                try a different port on the router
                • espesso
                  • 15
                  settings still the same, tried dif port. how do i know if image has gone read only?
                  • MetMan
                    • 1091
                    the changes u make would revert back to previous settings - they wouldn't save after a reboot
                    any firewall blocking?
                    • espesso
                      • 15
                      i saved the settings on dbox, does this make any difference? all firewalls turned off
                      • MetMan
                        • 1091
                        u got to save by pressing start /restart network settings....that's usually enough but u can save settings as well
                        the changes u make are still there after reboot??
                        what router is it? there's no security settings there blocking......
                        check ur pc network connection to allow local sharing...
                        right click on ur network icon in taskbar......click on status and support tab - do they match the addys u posted
                        • espesso
                          • 15
                          changes still there after re-boot
                          router: belkin f5d7230-4
                          local sharing allowed
                          addys as posted
                          • MetMan
                            • 1091
                            i use auto-negotiation but u can try changing the link speed/duplex mode to 10Mbps/Half Duplex in network settings
                            • espesso
                              • 15
                              changed from auto to 10mbps/half mode. still unable to ping. any ideas why i have only been able to connect usuing null modem? have used cross over in past to flash and no probs
