I've had the same kind of probs as Validus, can't ftp my box using either cross over ( pc to pc ) or direct via my router. Had to flash image via null modem using the tut from Aftermath ( worked a treat one of the best I've read), but I've still got to load the missing files. Can this be done using null modem cable? I've followed the advice given to Validus, when I test network now dbox is reachable (ping) but gateway and server isn't. Any ideas? 3 days and losing the plot!!
Trouble with FTP
did u check ur pc settings using the command prompt> ipconfig /all when using router - can u post theseI've had the same kind of probs as Validus, can't ftp my box using either cross over ( pc to pc ) or direct via my router. Had to flash image via null modem using the tut from Aftermath ( worked a treat one of the best I've read), but I've still got to load the missing files. Can this be done using null modem cable? I've followed the advice given to Validus, when I test network now dbox is reachable (ping) but gateway and server isn't. Any ideas? 3 days and losing the plot!! -
u got to save by pressing start /restart network settings....that's usually enough but u can save settings as well
the changes u make are still there after reboot??
what router is it? there's no security settings there blocking......
check ur pc network connection to allow local sharing...
right click on ur network icon in taskbar......click on status and support tab - do they match the addys u posted
ip[addy.jpgLast edited by MetMan; 23 December, 2008, 12:22.Comment
