sorry about that put the 16 files in var/keys
Nokia Dbox help - got an image but unsure
ok cheers.
ive got the general gist of things but could i just ask you if what im doing is alright.
1) flash commando 10c image using flash image assistant.
2) connect dbox + pc via ftp prog (e.g.filezilla, cute ftp or flashfxp) then add all those keys, emu's and bouqet + service files.
3) restart dbox and then search for all channels...
does this sound ok??
thanksComment
Thats all rightok cheers.
Don't forget to set your area before you do a scan you can find it by pressing the blue button
If you get stuck just shout make sure you put the right files in the right place have a look at my other posts m8Comment
Try rebooting your box as your box as just updated the k#ys so the first time will take a long time or restart your emu,Comment
Glad you got your head round it. That's it once you do it once it's a piece of pi##
It's good to see you got it sorted i new you would get there in the end.Comment
hi guys i have now got my head around emu files and the other 16 files as you showed but where do i find my local service files for bristol/ glouster area is there a different section i am missing
just a num. nuts learning
thanks for any helpComment
Services.xml is created when u do a scan. if you setyourlocation first, then reboot - when u go to scan it should have the correct settings for your area. do a fast scan and thats when it creates your services.xmlComment
depends if u want to try different emulators....evocamd most use and if that works ok stick with it.....other one that auto-updates is mgcamd.....gbox and newcamd can work but will not au and camd2 is for fta, soas long the img has room u can put in as manyas u like....some other files may need editing to use gbox, newcamd, it's img dependantComment
