Please, Please, Please Help
    Yes but he said he couldn't access the box via the remote. If thats the case then IFA is his only option.
    • buzzking5
      • 146
      #17
      help
      yes you can mate
        Can what ? i think i'll leave the stella alone i can't keep up here
        • buzzking5
          • 146
          #19
          delete roms in var/keys folder 10/11,overwrite rom7 all will be sweet
            If the screen is blank and he cant get anything using the remote, then replacing the roms wont make a difference.
            • PETERG
              • 203
              #21
              flashed new image
              Originally posted by gizmo.1484
              No just flp new image to var/tmp then on remote press dbox button then go to service press on that then go to update/back up/restore press ok then press on flash read image then press on write one partition then press on flash without bootloader then hi-lite image press ok when flash as finished then press red button the box will reboot
              Have flashed new image onto box using IFA, X-over cable & Null modem cable. LCD on DBOX now says
              FERTIG !
              (smiley faces)
              Is this OK
              what next?
              • gizmo.1484
                • 873
                #22
                You need to flash your box with a uk image it sounds like the image you have is german as fertig is german for finished
                • PETERG
                  • 203
                  #23
                  commando 10 image used,
                  used the commando 10 image, could the IFA be the problem, as the link to the site from the downloads area takes you to a german version, it does not clearly show a english version.
                    Digital Kaos - Downloads - Dbox2
                    Download it from here m8
                    • gizmo.1484
                      • 873
                      #25
                      When you press on the dbox button are the sections in english?
                      If you used a german ifa then the flashing would have been in german that explains why it said fertig.
                      Then the image is ok
                      Now press the blue button set location, reboot then do a scan.
                      After you have done a scan then post back,
                      • smoggie
                        • 863
                        #26
                        Originally posted by PETERG
                        Isnt commando 8 a U.K. Image????
                        DiSEqC mini-diseqc
                        satelite astra 19.2E
                        DISEqC - repeats 0
                        DISEqC - settings
                        sure that means that the image has reverted back to sat and not cable
                        • PETERG
                          • 203
                          #27
                          hAD ENOUGH TONITE
                          BOX SEMED TO FLASH WITH THE ENGLISH IFA FROM DOWNLOAD AREA (ALTHOUGH WHEN I OPENED THE IFA AN ERROR MESSAGE CAME UP)
                          PLUGGED BOX BACK INTO TV & CONNECTED EVERYTHING UP, SWITCHED ON, COMMANDO 10 IMAGE CAME ON TV, THEN BLANK SCREEN WITH FLASHING CURSER, NOTHING ELSE
                          WHAT AM I DOING WRONG????????????
                          • gizmo.1484
                            • 873
                            #28
                            It sounds like it did not flash properly.
                            What did the error message say?
                            Try and flash again it will say on the lcd flash finished when it is complete it can take 5 to 10mins
                            • smoggie
                              • 863
                              #29
                              does the box fully boot up, e.g you get bbc1 or any other channel on the lcd. i also might be worth trying to flash another image other than the commando one
                              • plasterer
                                • 1631
                                #30
                                Peter am in knowsley
                                Shout if your stuck................Paul
                                PAUL
