For pure 5401, they took them out of TSid 0005 and 0006, and bunged them both into TSid 004d, with ITV2 on Sid 1e18 and ITV3 on Sid 1e19
So it's easier just to edit your services.xml with Metapad. 7 Day EPG users might need to tweak epgfilter.xml too, depending on which version they're running.
TW and exC&W users- sorry, you're on yer own, LOL!
Sorry mate but I haven't a clue. Has anyone got the required .xml files that I can upload?
Or can i restore these files that came with the image?
How do I scan for channels. At the mo its saying transponder fail or something.
Cheers
put you net id in (setmylocatrion frequncy sybbol section scan on, fast scan on save stettings and the scan. and youll find the missing channels in boquet editor
To do a scan press the blue button and set your location then the box will reboot then press the dbox button go to service then service scan put scan for service on all service put bouquet on update then put cable provider on cable uk then press on scan then the scan will start
There should be a option in the scan menu to turn it off.
Also make sure section scan is off.
Is it picking up any transponders? If not then instead off setting your location for your area then try setting it for your county as i had the same problem with my area so i set it to my county and it scanned first time
When you set your location it changes them automatic that's why you can not change them.
Teesside that's in liverpool?
Set your location to liverpool then try again
