make sure in the dbox network settings that dhcp is not ticked and connect to network is enabled
cant connect to dbox2 via ethernet
try full duplex thats what i use,no antivirus on/firewall etc...have you a desktop comp as well make sure there are no conflicts there eg:turn router of modem etcc..mComment
so i did as instructed. turned off dchp, corrected the ip add and correct subnet mask.
then i saved the settings. i then used another lead, which was also a cross over cable.
AND HURRAY! it worked superbly guys!
THANK YOU SO MUCH FOR ALL YOUR HELP EVERYONE!
i have just installed the commando 11 image, which is flipping great i thought! one of me boxes is a bit temporemtnal, but loving it now!
THANK YOU SO MUCH AGAIN ALLComment
