cant connect to dbox2 via ethernet
  • ss0000
    • Mar 2009
    • 151
    #16
    make sure in the dbox network settings that dhcp is not ticked and connect to network is enabled
    • siddiqi1
      • 69
      #17
      Originally posted by MetalKettle
      What cable you using? Re you going direct to the box or thru a router?
      going direct via a cross over cable
      • mickydibble
        • 2166
        #18
        try full duplex thats what i use,no antivirus on/firewall etc...have you a desktop comp as well make sure there are no conflicts there eg:turn router of modem etcc..m
        • mr.mojorisin
          • 247
          #19
          make sure dbox DHCP is OFF
          i think this is found under network settings
          • thebigman
            • 176
            #20
            after you changed the settings on the dbox and saved them, did you restart the network? or reboot to activate the new settings?
            thebigman
            • siddiqi1
              • 69
              #21
              so i did as instructed. turned off dchp, corrected the ip add and correct subnet mask.
              then i saved the settings. i then used another lead, which was also a cross over cable.
              AND HURRAY! it worked superbly guys!
              THANK YOU SO MUCH FOR ALL YOUR HELP EVERYONE!
              i have just installed the commando 11 image, which is flipping great i thought! one of me boxes is a bit temporemtnal, but loving it now!
              THANK YOU SO MUCH AGAIN ALL
              • ManofScience
                • 650
                #22
                glad it's working!
                • siddiqi1
                  • 69
                  #23
                  me tooooooo! all the channels as well ))))))))))))))
