hi chaps can anyone tell me why i cannot watch sky 1 i have sky 2 and 3 and can watch them fine got all the channels tried scanning cant seem to sort this one out
sky one no channel found
Tags: None
cheers mate i've done all that what seems to happen is when i do a scan it finds every channel apart from sky1 but after a few days it appears so then i can add it to my bouquets when i change to sky1 it says channel not available the epg is there i've tried changing the ucode but still the sameComment
i did have a little look last time it seemed ok also done a rescan after i cabled it up straight to the wall socket i have had situations in the past relating to poor signal but usually only scans a hand full of channels never leaving just one out it seems strangeComment
seems a signal issue but it looks more like it could be an old freq and has been moved to anther frequency. What image are you using? In the service scan menu make sure 'sections scan' (or 'autoscan' ) is turned 'on'. Also reload 'channel list'. if channels are moved this automatically finds the channels, though they could be found in another bouquet eg unsorted check other bouquets too. Hope this helpsComment
sky one has the a crap signal . then only way l found it was to install someone else's bouquet ,any information provided is for educational/experimental purposes only.Comment
cheers for that when i install an old service file i still cant view it i'm using laky sylas but i've updated it to do the bruteforce scanseems a signal issue but it looks more like it could be an old freq and has been moved to anther frequency. What image are you using? In the service scan menu make sure 'sections scan' (or 'autoscan' ) is turned 'on'. Also reload 'channel list'. if channels are moved this automatically finds the channels, though they could be found in another bouquet eg unsorted check other bouquets too. Hope this helpsComment
old services file wont work if the frequency changed after saving this services file. Check for an up to date services & bouquets files in the dload section for your area or make a request for a latest working services file quoting the area you live in. Somebody in your area might have a working file and help you.
By the way how did you update the image to be able to do the bruteforce scan on laky sylas?Last edited by ss0000; 1 July, 2009, 12:32.Comment
cheers mate tried asking for a service file many times for my location with no response to change it to a bruteforce follow this linkold services file wont work if the frequency changed after saving this services file. Check for an up to date services & bouquets files in the dload section for your area or make a request for a latest working services file quoting the area you live in. Somebody in your area might have a working file and help you.
Finding no Channels or loosing channels after a service scan FAQComment
Recently I lost the e4 and e4+1 channels and in the bouquet editor in the dbox-services menu I deleted these non-working channels from my 'freeview' bouquet. These moved to the 'unsorted' bouquet. I kept on 'reloading channel lists' every time I sat to watch telly. And after a few days I got a 'new channels' bouquet with the working e4 and e4+1 channels which I transferred to my 'freeview' bouquet.
You have to make sure sections scan is on and it should (hopefully after a bit of patience!) find the channels not already found.
Another problem could be weak signal causing the channel to not work. If you have a signal booster might be worth a try scanning with the booster connected. My dbox does not work without a booster as the tuner is weak
Hope this info helpsComment
