freezing!
  • johnlogie
    • 44
    #16
    Try changin the ucodes m8
    • plasterer
      • 1631
      #17
      As above John LOl
      PAUL
      • enery8th
        • 13
        #18
        think i got it fixed...changed the cam ..all cams were selected except one selected the one that wasnt seletcted and disabled the others...still does it from time to time but not nearly as much! ill keep my fingers crossed
        • jaytag
          • 82
          #19
          i have the same problem but ive been told its my snapshot image.is this true as i dont know anything about dboxes and 2 with the sameproblem
          • muckpig
            • Aug 2008
            what do you mean when you refer to "cam"
            where do you change the cam?
            ive got a similar problem with channels freezing for 30 seconds
            if i try and move off channel and back on this seems to occasionally unfreeze the channel quicker than waiting
            • MetMan
              • 1091
              #21
              the cams are the methods of emulation....mainly 4 types, evocamd, newcamd, mgcamd and gbox not all au and not all in imgs....he must a tried a different one and it seems to have improved the freezing.....gbox cam is renowned for helping this issue but it will not au, there are some imgs have a script written to switch to evocamd to update then switch back to gbox when theres a k*eyroll.
              hope this helps
              • skinterz
                • 89
                #22
                ive had the same problems ,every 4-5 min screen freezes for 10 seconds its really annoying i got the booster and did a new scan still freezes .
                i cant see how i can go direct to cable box for my tv as i have my internet connection running off the splitter.
                • enery8th
                  • 13
                  #23
                  cams
                  press the blue button then service menu then keys menu then nagra image i just tried enabling and disabling different ones think its worked for me..its definatly better so far still freezing a little on some channels from time to time
                  • skinterz
                    • 89
                    #24
                    i got four nagra rom three were enabled should there just be one rom enabled ?
                    • gizmo.1484
                      • 873
                      #25
                      Rom 7 is the most used so disable 3-10-11 this should sort it out as when they are all active it takes longer to update them........
                      hope this helps m8
                      • skinterz
                        • 89
                        #26
                        hope this helps m8
                        thank you m8
                        • redhound
                          • Aug 2008
                          • 33
                          #27
                          the tuner gets hot also,remove the modem to improve air flow.
