DBOX 2 not booting up after flash with blade quad
  • 0103953
    • Aug 2008
    • 5
    hi there.
    i am a newbie to the dbox and recently flashed my dbox with the blade quad image. i am having some problems unfortunately getting the box to start up. i have connected this through ethernet and successfully flashed images onto it already (unfortunately older images). after doing some research i seen the most critically acclaimed one was the blade quad image. i then decided to flash the box but ran into a problem.
    the box restarted and gave the logo for the image and the LCD display showed the Virgin Telewest logo. the LCD display then showed 'loading kernel' and the box just goes no further.
    ive tried rebooting the box but it will stay stuck on 'loading kernel'
    im resigned to now flashing it again via NULL modem cable. does anyone have any advice on if ive done anything wrong.
    am i correct in thinking that simply flashing the image and running a scan for the channels is all i need to get it fully up and running.
    any help on this would be greatly appreciated.
    Col
  • gizmo.1484
    • 873
    You will have to use a fta program now to flash your box.
    Where did you get your image from as it could be corrupt try flash with the same image and see what happens if same thing try another image...
    When you have flashed successful then just scan
    • krazylegz
      • 2834
      the first thing to do is make sure you have the correct image for your box ie 1x or 2x m8.
      if you have the correct one then is is possible that the image was corrupted when downloaded, if so try and flash again
      PS3= krazylegz120282
      • sbance
        • 48
        Originally posted by 0103953
        hi there.
        Col
        I would use a IFA to try flashing the image again. Ensure your have the correct image for your dbox (ie 1 or 2).
        Get the lastest IFA here which runs on vista
        Connect this up with a null modem and then reflash the image onto the box.
        Once you have successfully flashed the image and it is working properly we can get the channels and make it work.
        • 0103953
          • Aug 2008
          • 5
          thanks for the advice so far. i purchased a NULL modem cable which should be arriving in the post today.
          what version of the blade quad image should i use and where is the best place to find it? ive heard blade quad nuetrino is quite good but no sure where to find a copy.
          by the way its a 2x Nokia Dbox that i have
          • gizmo.1484
            • 873
            There is one in downloads but has no k*ys or r*ms installed.
            You will have to put them in yourself into var/k*ys.
            • 0103953
              • Aug 2008
              • 5
              ive got the BigMAQ toolbar. is this the best place to get the updated key files?
              • gizmo.1484
                • 873
                The images there have the k*ys in the image already so all you need to do is flash the image and scan.
                • krazylegz
                  • 2834
                  or get the keys from here they work perfectly
                  RapidShare: Easy Filehosting
                  • 0103953
                    • Aug 2008
                    • 5
                    brilliant. ill try it out and see how i get on.
                    thanks again for the advice.
                    <--0103953 added 65 Minutes and 19 Seconds later...-->
                    Hi krazylegz i cannot see links in the forums yet as i am a new user. are you able to pmm or email me the link to the keys?
                    many thanks
                    • krazylegz
                      • 2834
                      just emailed you m8
                      • soggybiscuit
                        • Aug 2008
                        • 8
                        hi i am having the same problem...
                        its stuck on the loading kernel part...
                        i tried using IFA at first but didnt seem to connect...
                        so i tried ftp...
                        during the ftp it only did about 700kb and then stopped
                        now i dunno what to do...
                        have I bricked it?
                        not even sure if i can ftp to it or ping it now
                        • krazylegz
                          • 2834
                          try IFA again and you might have to use a null modem, but IFA usually sorts it with a standard RJ45 crossover cable.
                          if the box isnt booting up fully you're totally wasting your time trying to ftp
                          • redhound
                            • Aug 2008
                            • 33
                            a early version of ifa is needed as later versions try to backup a failed flash and leave you back to square one.
                            a long time since i have fiddled with these and dont use them anymore.
                            • aftermath
                              • 4345
                              If all else fails read here
                              works fine on XP,
                              Vista has a different version, explained in the later posts in the same thread.
