Problems with Flash FXP - Help?
  • hendinho
    • Aug 2008
    • 16
    Right - i'm running Blade Quad 1x on a Sagem DBox2 (flashed okay)
    Computer IP: 213.106.193.212
    Router IP: 192.168.1.1 (found on a web site)
    with DBox connected to the TV i went into Settings -> Network
    and chaged the following
    ip address to 213.106.193.213
    default gateway to 192.168.1.1
    dns server to 213.106.193.212
    Then i connected dbox via ethernet cable to my router and turned it on
    Ran Flash FXP
    Try to connect to dbox by entering
    IP: 212.106.193.213
    Port: 21
    User: root
    Password: ive tried dbox and dbox2
    and it wont connect so i can't transfer keys etc...
    feeling helpless
    Any ideas?
  • tottenhamyid
    • Aug 2008
    • 5
    DNS server should be set to 192.168.1.1, this should be the same as your gateway. Give that a go, should be ok
    Tottenhamyid
    • hendinho
      • Aug 2008
      • 16
      just tried that and still no joy..........
      i've just no idea
      • MetMan
        • 1091
        i've just no idea
        check ur pc ip and router address, command prompt >ipconfig /all
        or try >arp -a
        • hendinho
          • Aug 2008
          • 16
          so.... i'm assuming i change IP of the dbox to 192.168.1.102? one number diff to my PC IP?
          • MetMan
            • 1091
            personally i switch bsck to dynamic let your pc find its own address within the range of ur router....likely to be 192.168.1.2 or 102 then set ur dbox settings.....
            • hendinho
              • Aug 2008
              • 16
              cheersforthis - it was my brothers PC he gave me so how would i go about switching "it" backto dynamic?
              • MetMan
                • 1091
                control panel - network settings - right click on adapter -properties -internet protoocol (TCP/IP) - props - obtain ipaddress automatically / ok
                • hendinho
                  • Aug 2008
                  • 16
                  using vista so wasn't that stright forward but found what i believe to be the right bit and there are two diff ones - both already set to auto obtain IP
                  based on the info above what settings do you suggest i try in the dbox?
                  give it an IP one away from my PC IP? e.g 192.168.1.102?
                  • MetMan
                    • 1091
                    yep ....start /reset then try to ping / test network u r looking for 4 pings - takes a little while
                    • hendinho
                      • Aug 2008
                      • 16
                      1st = (ping)
                      2nd and 3rd are apparently unreachable
                      as well as the 4th
                      • MetMan
                        • 1091
                        1st = (ping)
                        as well as the 4th
                        try 202 and ping or
                        try dbox 192.168.1.103
                        gateway 192.168.1.1
                        server 192.168.1.102
                        or
                        dbox 192.168.1.203
                        gateway 192.168.1.1
                        server 192.168.1.202
                        or
                        try dbox 192.168.1.102
                        gateway 192.168.1.1
                        server 192.168.1.101
                        • hendinho
                          • Aug 2008
                          • 16
                          same result i'm affraid.i though the default gateway and dns server where meant to be the same?
                          • Fergal
                            • Aug 2008
                            • 1007
                            Right click on your pc nic choose properties then configure tab then advanced and set flow control,duplex or media type (could be called something else also) to 10baseT_halfduplex or 10half mode
                            • MetMan
                              • 1091
                              no the server is the pc that's connected to the router the gateway is the router
                              did u try the last address i posted, if so go into ie h**p://192.168.1.1/
                              and check ur router settings - starter ip adress 192.168.1.100 on the basic set up page
