n00b :)
  • mickydibble
    • 2166
    #16
    seems fergal is offline....blue button twice ,it will then give option to set location,....you will need the magic files on once you know your ready to go by getting fta channels
    • koff
      • 32
      #17
      hey, ive just put the magic files on, managed to select location but when I do scan with fast scan on I get no results
      i also noticed on bouquet editor there is nothing there, should there be?
      • mickydibble
        • 2166
        #18
        choose the nearest location try that....m
        • koff
          • 32
          #19
          got location but still no luck,^^
          • Fergal
            • Aug 2008
            • 1007
            #20
            Make sure cable provider is the same as the symbolrate in the scan menu then red to save and blue to scan
            what image did you flash on.
            • mickydibble
              • 2166
              #21
              no channels at all? any fta channels?bbc etc
              • koff
                • 32
                #22
                what do you mean by this?
                used this image... commando-11_powered_by_ukcvs_2x
                • koff
                  • 32
                  #23
                  no mate it just says scan for channels
                  • Fergal
                    • Aug 2008
                    • 1007
                    #24
                    In the scan menu it says cable provider hi lite it press ok it should give you different choices
                    • mickydibble
                      • 2166
                      #25
                      go to scan settings and change symbal rate/cable provider
                      to a different number eg 6952 because it depends what provider you was with before vm telepest/nthell
                      • Fergal
                        • Aug 2008
                        • 1007
                        #26
                        Thesymbolrate is set when you do the setmylocation feature
                        i mean were it says cable provider its about the 2nd or 3rd line down in the scan menu change it so its got the same number as the symbolrate
                        IE: symbolrate= 6952, cable provider6952
                        • koff
                          • 32
                          #27
                          under cable provider i get the options of cableuk, dvb-c ireland, dvb-t ireland, and chorus ireland
                          symbol rate is on 6952 not sure what I should change either of these 2 options to?
                          • mickydibble
                            • 2166
                            #28
                            No i dont the symbolrate is set when you do the setmylocation feature
                            oh ok ferg you crammed git, oh yeh its blue button twice to set location m8...were all here to help you goon
                            • Fergal
                              • Aug 2008
                              • 1007
                              #29
                              Right commando image (they love to change things from the norm) leave it set to cable uk what area you in
                              • Fergal
                                • Aug 2008
                                • 1007
                                #30
                                Is there any need for personal insults
                                Not on all images you dont some images you only press blue once and we did not know what image he had flashed on.
