help needed plz dbox2 nokia sportster 1.75
  • tom01793
    • Mar 2010
    • 5
    hi all i have just puled out my dbox witch i have not used in a long time,
    i have plumed it all in but i cant get it to work it all powers up fine and boots ok,
    but when i go to scan channels it does not do anything also it seems to have still got old chanels on there from a long time ago,
    i have moved house since then how do i resolve this problem thanks any help would be nice
  • braindead
    • 103
    Have you moved from an ex NTL to TW area or vise versa?
    If so you will have to scan on a different frq
    • tom01793
      • Mar 2010
      • 5
      it was a good few years ago when virgin just came out might ov even been ntl,
      i am now on virgin media area swindon wiltshire,
      when i scan for chanels it says finished ok but there are chanels on my list but no pic?
      • tom01793
        • Mar 2010
        • 5
        can anybody plz help with this?
        • kelvie09
          • Jun 2009
          • 23
          try flashing new img with flashfxp, (comm 12) is quite easy to use. then just add the magic and sevices and bouquets and do a scan, should sort it 4 now
          • tom01793
            • Mar 2010
            • 5
            so what is the best img to put on the box also is it easy to do
            • kelvie09
              • Jun 2009
              • 23
              well ive just put command 12 on my nokia 2x and it works fine and yeah this was the first time i have ever flashed a box myself and i worked it out straight away.
              just use flashfxp from d/load section, works with e/net cable and just put the files in correct places reboot box and away u go m8.
              if u need help just ask
              kelvie
              • tom01793
                • Mar 2010
                • 5
                kewl willl have to giv it a go
                • PaphosAL
                  Old Git
                  • 1064
                  Bear in mind that you'll need to apply last Monday's Update in order for Bruteforce Scan to function properly, plus a couple of other enhancements mentioned in the C12.1.2 release notes in that post.
                  Cheers- AL
