hi guys does anyone know how to get rid of the voice commentry on the movie channels ive got the commentry on all of them now, dbox2, cheers...
re vioce commentry
Off the top of my head m8, change the audio settings. I think the one you have is nar.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
thanks alot guys it was green button then english, thank god for that it was doin my head in
, chris..
A LITTLE THANX GOES A LONG WAY
Knew it was something like that
On standard neutrino images, Audio Description can only be turned off on a per channel basis. And there's no guarantee the individual settings will be maintained after a reboot.
On Commando 11.3 and 12, Virgin+ 3.0 and ultraPhat Apocalypse, there is a cool LraiZer option in Audio Settings to turn off AD globally for ALL channels! It is the the default setting in the release versions.
Cheers- AL
there are a couple of extra audio options in the ultraphat apocalypse image. it has the following 4 possible audio setting combinations.On standard neutrino images, Audio Description can only be turned off on a per channel basis. And there's no guarantee the individual settings will be maintained after a reboot.
this would be option 4 in the ultraphat apocalypse image
Cheers- AL
1) autodetect English (default)
settings > audio > audio selection (if available) > English
2) autodetect Narration
settings > audio > audio selection (if available) > Narration
3) uses 1st available audio channel
settings > audio > audio selection (if available) > off
settings > miscellaneous > zapit > save audio-pids > off
4) uses a saved per channel audio map
settings > miscellaneous > zapit > save audio-pids > onComment
