Guide:How to FTP the fix into the Dbox for noobs
  • manunited20185
    • 114
    #46
    hiya i have followed every instructions you have mentioned but it doesnt work. when i used the cute ftp, i get this message saying, "Can't read from control socket. Socket error 10054". and when i used the flash fxp it says "connection failed. no route"
    i need help please
    • moin
      • 178
      #47
      il try this later thank u r jenious person
      • mickeyd82
        • 30
        #48
        can i just say,whats goin on ere when joing pc/laptop to the digibox's? Soryy but didnt know you could
        So what do you get as im interested?
        Cheers
        Mike
        • mr.mojorisin
          • 247
          #49
          thanks from me too.i'm a total noob and hope this works
          • casaamdterdam
            tanks a lot for help !
            • Dodzer
              • Aug 2009
              #51
              thanks for the help
              • tkm18
                • Aug 2009
                • 158
                #52
                Ive been wresting with this for a couple of hours.
                Is the DHCP to be off or on??
                The OP say DHCP should be off, but when you open the attached doc it says ensure DHCP is Enabled.
                I keep getting, timed out when i try to FTP into the box using FlashFXP, really doing my nut it big time.
                Or am i missing something dead simple.
                • gizmo.1484
                  • 873
                  #53
                  You need to turn DCHP off. If you keep getting timed out then make sure the ips are set up right,
                  • Mubz
                    • 168
                    #54
                    turn off DHCP and set your own ip addy...
                    can you ping the box?
                    Mubz
                    Growing old is inevitable, growing up is optional ...
                      Turn dhcp OFF. Manually assign an ip to both your box and pc network card.
                      IE box 192.168.1.5
                      pc 192.168.1.4
                      • tkm18
                        • Aug 2009
                        • 158
                        #56
                        Cheers guys, ive a feeling its something really dumbass stoopid im overlooking.
                          Check your firewalls off too m8
                          • mickydibble
                            • 2166
                            #58
                            It will be! But just follow advice mentioned. Check ips before FTP sometimes the box resets it's ip when your going through the motions.check connections of Ethernet ,disable anti virus:firewall
                            Don't give up it is better to just start again
                            • tkm18
                              • Aug 2009
                              • 158
                              #59
                              Its a fresh XP install, nothing on the computer except the dbox stuff, windows firewall is off.
                                Have you tried ftp wirelessly ? I prefer to do it this way.
