help connecting dbox to pc
  • street_pharmacy
    hi
    i recently connect my dbox to my pc through my router.. i then messed bout with my ip on my dbox now i cant connect to my dox with filezilla.. but not only that but my dbox now doesnt load so i cant chk my ip adress..
    can any1 help me plz.
  • hectorplasm
    • 29
    HI IF YOUR LIKE ME
    I HAD THE SAME PROBLEM THIS WEEK
    DONT CONNECT THROUGH YOUR ROUTER CONNECT DIRECT TO YOUR NETWORK CARD YOU MUST USE A CROSS OVER CABLE SLIGHTLY DIFFERENT WIRING TO THE NORMAL CABLE I WONT BOTHER PUTTING THE REST DOWN UNTILL YOU KNOW THAT YOU HAVE THE RIGHT CABLE
    THANKS
    • Salami
      • 535
      Originally posted by street_pharmacy
      hi
      flash the image again and don't mess about with the IP address M8
      If you like my post pleas click on the little button to say thank you.
      • hectorplasm
        • 29
        SORRY I DIDNT READ THE THE QUESTION RIGHT
        • Salami
          • 535
          I forget to say for exemple:
          If the dbox IP: 192.168.1.5
          Filezilla IP the same as your Dbox
          local area connection should be: 192.168.1.4
          Local area Connection one number less at the end of IP address of your Dbox.
          • father ted
            • Feb 2008
            • 1389
            hi
            you need to reflash your box with ifa
            • Salami
              • 535
              Hi Father ted how you doing we all missed your help M8.
              • on_the_jazz
                • 557
                As Ted said you need to reflash with IFA.
                Also don't worry about connecting through a router, its fine. And feel free to change your ip. You don't have to have the one given to you. Just ensure the first 3 octets are the same as your network. The last octet can be anything you want.
