they are both 2006 boxes blue and are both clones. when i flash them they come up with normal writing but when i retreive my box with the rf lead all the writing scrambles get perfect picture just cant read none of writing
Just going back to a previous post you say they are fine after the flash, SO why do you need to "retrieve" them via the RF cable? if you can SEE they are fine via the TV screen just proceed to power-scan.
OR am I missing something BESIDES the will to live .
as hiteck says, cant understand why you are plugging rf cable back in when scart is working,
the reason for using rf connection is because scart gets knocked out if you flash box with wrong firmware.
do a factory reset then power scan without rf lead in .
its the stuff we think we know that stops us all from learning
the only reason i know it would do that mate is that if is a clone blue box and you put the genuine f/ware on it ,i have had this happen a few times but have always managed to get the box back up and running using the help from this site ,good luck m8.
we could have lift off i managed get writing back on but when i unplug it to take it bak down stairs to set up again it freezes again shall i keep that one in my room
just as a precation m8 check your downstairs cables i.e. scarts and cable feed ,you never know.
