problems with blue box
  • camelv
    • 1202
    #16
    also you can just right click the rar file and select 3rd extract file down then double click it and it will apear as a folder on your desktop
    mornin hi-teck
    its the stuff we think we know that stops us all from learning
    • HiTeck
      • Oct 2008
      • 996
      #17
      Morning
      • warriors5
        • 23
        #18
        when i do factory default im still gettin scribble writing
        • camelv
          • 1202
          #19
          Is this through the RF connection
          • warriors5
            • 23
            #20
            yes through both scart and rf connections
            • HiTeck
              • Oct 2008
              • 996
              #21
              Originally posted by warriors5
              they are both 2006 boxes blue and are both clones. when i flash them they come up with normal writing but when i retreive my box with the rf lead all the writing scrambles get perfect picture just cant read none of writing
              Just going back to a previous post you say they are fine after the flash, SO why do you need to "retrieve" them via the RF cable? if you can SEE they are fine via the TV screen just proceed to power-scan.
              OR am I missing something BESIDES the will to live .
              • camelv
                • 1202
                #22
                as hiteck says, cant understand why you are plugging rf cable back in when scart is working,
                the reason for using rf connection is because scart gets knocked out if you flash box with wrong firmware.
                do a factory reset then power scan without rf lead in .
                • warriors5
                  • 23
                  #23
                  it comes up with wriring on after flashing it for about 10 seconds then freezes and goes back to were i need put rf lead in to get it going again
                  • camelv
                    • 1202
                    #24
                    the only reason i know it would do that mate is that if is a clone blue box and you put the genuine f/ware on it ,i have had this happen a few times but have always managed to get the box back up and running using the help from this site ,good luck m8.
                    • HiTeck
                      • Oct 2008
                      • 996
                      #25
                      Do as camelv said previous and put the Old clone fix firmware back on it from April 16th linked earlier on in this thread and see if it's the same.
                      • warriors5
                        • 23
                        #26
                        we could have lift off i managed get writing back on but when i unplug it to take it bak down stairs to set up again it freezes again shall i keep that one in my room
                        • HiTeck
                          • Oct 2008
                          • 996
                          #27
                          Go on then, tell us how you got the writing back.......
                          • camelv
                            • 1202
                            #28
                            just as a precation m8 check your downstairs cables i.e. scarts and cable feed ,you never know.
