Download a fresh copy of the loader and firmware directly to your old PC. Do not use the ones on the memory stick and then try again, as said persistence will eventually pay off when doing a hard boot.
digivox help"
hi satsmo, i have the digivox , going again , got the file to free it , its back to the normal menu" , have scanned for chanells. , have them on the tv list, all of them , but its saying (data being updated 0% ) " i have the emu set to on , and the provider im useing (named ) in the box , i could put the codes in the code box , if i have too , but i was hopeing that the box would update itself on auto , thanks again ranger ....Comment
the download worked this time and the box is back to normal menu , but sitll saying ( data being updated 0% ) i was hopeing that the file would set the box to update itself to auto update , i have the emu , set to on , and the channel provider (named ) in the scann box , any ideas how i can get it to update itself on auto ,, thanks again ,, range ..Comment
hi satsmo, i have tryed powering off , like you said , and trying to update on sky sport, the first time i tryed it ,it was flickering on and off , looked like it was going to start, but no" i have , the emu on , and ntl in the scann box , ,i tryed a factory reset, still saying( 0% updateing ) the s/w verision , is v04-1.00 bk boot v 01 date 29 nov.2008. any ideas , im in dublin , on ntl thanks ,,,,,,, rangerComment
in blue digivoxv4300 i downloaded it so it worksThis is the latest firmware for your model Digital Kaos - Downloads - Digivox V4300 and downloader 10 is the correct loader, which you must be using.
You can get it here you may a corrupt loader, so worth a fresh install.
Carry out a factory reset, turn off the box from the power for a minute and then back on. Keep trying a hard boot flash as said it will work eventually.Comment
