Thanks, i will wait to see if anyone can confirm if they are clones or not, i will be sending the two unopened boxes back but i would like to get the opened oned up and running.
Three EUROVOX EX1000L's dead, HELP!
I got the pm cheers. But as I said in my reply, you need to do as HiTeck said and send them back, even the opened one. They will replace them, they have done so before.
For three to go at the same time its not just a hardware issue.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Thanks, i will be sending them back (all three), i would just like to ask, is the box in the pic i posted a clone or genuine box? i ask this as i would then know if i should ask for a refund or replacement.
Thanks!Comment
As Satsmo said he did reply to me and confirmed to me as thought after seeing the pics it was a genuine EV, either way it makes no odds, send them all back also send him the link to this thread if he refuses to refund you also let us know of the outcome.
I have only seen one clone sl there was no red super glue everthing is identical to original the only give away was the packing box it came in it was very poor quality ,if the guy you got it from also is still selling 5000 pvr then chances are you have clones hope i am wrong
alexComment
I think its the latest firmware that has a lot of problems? If you fix them by Jtagging them? Try the version before February. I've heard a few complaints from people with the same problem.
Hope you get it solved> For 3 to die its definately a problem with the software on the box. The parts inside arn't cheap chips. I can't comment on the power board thoughComment
is this the beginning of the end ?I purchased three EX1000SL's and updated the firmware, they all seemed to work fine untill the boxes (all three) where unplugged from the wall and plugged in again, at this point the boxes froze and theres no power at all, not lights on the front red or green, can anyone help, PLEASE!Comment
where is the tsop for sl1000 ?I think its the latest firmware that has a lot of problems? If you fix them by Jtagging them? Try the version before February. I've heard a few complaints from people with the same problem.
