eurovox favourites list keeps messing up!!
  • jimifloyd
    • 31
    whenever i do a update channel scan on my eurovox ex1000sl all my favourites keep gettin messed up so i have to go through the boring chore of setting them up again (sports,music,movies,u know what i mean!) is there anyway how i can keep them all?? its only when a channel is scrambled and i have to re-scan!!! obviously its worth it really with all the footie on (lovin espn classic!!!) but a bit of a ballache at the same time!! any help guys???
  • fearlessimon
    • 172
    i had this problem then found i could scan a channel individualy so if one went scrambled i would just scan that frequency which keeps my favourites
    Dont eat yellow snow
    • smoggy
      • Apr 2009
      • 12774
      you need to turn off fav sort (this is how on a max v)
      Menu/instalation/fast install
      press red button
      scroll down to fav sort and turn it off
      then press exit (do not press OK) if you press OK all favs order will go back to default order.
      also there are two firmwares for your box one has the fav sort option the other is the nosort version which has it permanently turned off
      • rockville
        • Jun 2009
        • 35
        Quick question.
        Any idea how I'd go about scanning for an individual channel on a EX5100 PVR. Every so often 1 channel disapperas and it'd be easier to just rescan for that particular channel than doing a full scan.
        • smoggy
          • Apr 2009
          • 12774
          Originally posted by rockville
          Quick question.
          when a channel is moved to a different frequency all you get is a blank screen with a message saying something like no signal/bad or scrambled channel etc.
          The only way to get that channel back is to rescan or find out off someone in your area what frequency it has moved to
          if it is still on the same frequency but somehow its gone blank then you can press the info button twice on the remote and it will show the frequency of the channel
