hi i have a eurovox ex1000sl, everything was fine till this morning then i got a "no audio/video data" message on channel 5, how do i sort this problem, im on VM in the edinburgh area if this helps, thanks in advance.
no audio/video data message on eurovox ex1000sl
Tags: None
hi mate, i dont know if you sorted your problem but if you didnt here`s what you have to do:-
go to the affected channel
press info twice
make a note of the frequancy
press menu
go to installation
fast install
enter pin (usually 0000)
press red
move down to fav sort
press side button to turn off
press exit
find the affected frequancy
press ok to put tick in box
press green
the screen will go blank for about 30 seconds, then the channel should be sorted, and all your channels will still be in the correct order. if any other channels are showing the same message or scrambled channel, then just repeat this process.Comment
Hellohi mate, i dont know if you sorted your problem but if you didnt here`s what you have to do:-
press info twice
press menu
go to installation
fast install
press red
press exit
press green
I've just followed instructions and channels are back - just wanted to ask isnt this a manual scan? Only reason im asking is because channel order has been lost
- this normally happens on a manual scan but just thought u'd found a way of keeping channel order!
Thanks anyway.Comment
