All channels gone missin!!!!
  • verl08
    • 5
    I was having signal problems so i reset factory settings and downloaded the firmware again. Now when i do a power scan it doesnt find any channels. Anyone got any ideas?
  • smoggy
    • Apr 2009
    • 12773
    did you scan on the correct symbolrate
    maybe for some reason or other you have lost your signal
    • sarolium
      • Jun 2009
      • 50
      If you are using a splitter on the feed remove the splitter and attach the cable directly to the incoming feed then rescan maybe try a deep scan. Also check that the factory reset has not altered the settings for the symbol rate for your area.
      • greenbird
        • Mar 2009
        • 7
        one channel froze this morning for me too.
        Did a rescan but another channel was frozen, now i have the same problem as verl08
        • chic.
          • 1599
          have you tried your subbed box to see if that it ok
          if i helped hit the thanks btn
          • greenbird
            • Mar 2009
            • 7
            all seems ok now
            • verl08
              • 5
              Everything seems to be working again now!! is there a way to boost the signal on the eurovox ex5000 cos the signal is rubbish?
              • smoggy
                • Apr 2009
                • 12773
                what signal are you getting
                there is the option to enable the signal booster in the menu/config options
                • verl08
                  • 5
                  Thanks for pointin that Signal Booster out. Everything seems to be sound now! Will it Boost the signal enough to allow a split to another box?
