EX700 HD channel file / firmware
  • steamroller
    • Jun 2009
    • 16
    Do i load the firmware first then the channel file? Or the channel file first then the firmware?
  • dasteph
    • 1293
    firmware first then channel file.
    • ace3314
      Any one got menu pin for eurovox ex700 hd. Defalt 0000 dust work.
      • smoggy
        • Apr 2009
        • 12773
        Hi and welcome to DK
        the master pin is 6502
        • ace3314
          Hi DK tride that pin but did not work. Is there a way of flashing the box with out using the menu or dos the box nead J taging.
          • chic.
            • 1599
            Hi m8 take a look at the last post on this thread http://www.digital-kaos.co.uk/forums...ly-rest-43904/ ps welcome to the forum
            if i helped hit the thanks btn
            • morrisnapper
              hi all
              any joy gettin new firmware for ex 7000 box
              • dasteph
                • 1293
                Originally posted by morrisnapper
                hi all
                there is no firmware/update that will overcome n3 encryption.
                • morrisnapper
                  is this to say are eurovoxes are useless and should be binned
                  • dasteph
                    • 1293
                    yes if you want but you will still recieve channels 1-5 and a few others that remain unscrambled but for premium channels free tv is over.
                    • Floyd
                      • 99
                      I would like original firmware for ex7000HD
                      Can anyone help with this please?
                      • smoggy
                        • Apr 2009
                        • 12773
                        why do you want the original firmware as it will do nothing more than any other firmware
                        • Floyd
                          • 99
                          Because I believe it will give some HD freeview channels, for example ITV1 BBC! Channel 4
                          I just wanted to try and just use it as a freeview HD box.
                          • smoggy
                            • Apr 2009
                            • 12773
                            doesn't matter which firmware you put on the box you will get nothing different as to what you are getting now.
