ok go to downloads get the latest firmware 12/3/09 click it to unpack it then rename the flash flash.tbn when you have done this put it onto your memory pen then into the back of the box switch off/on at the back of the box the box will reboot find the flash and install it when this is done press menu > deep installation > scroll to your symbole rate then press the blue btn all done good luck
I'm new in this forum. I just bought a hd7000 but i don't know how i can manually put the codes. Is anybody can help please?
I prefer to put codes rather than updating the S/W as it would affect the warranty.
Thanks a lot
Thabk you very much guys I updated and it work perfectly. I have just noticed that the strength and quality level is above 90% hwereas with my eurovox Max it was about 80-85%. I wonder if it is normal.
